Old 03-20-2005, 10:46 PM   #1
crawdad
crawdad's Avatar
Removing rear leaf springs...HELP!
I've got a '72 C-10 with leaf springs. I'm in the process of removing the srings, axle, and everything to clean it up and paint it. I've tried 3/4" sockets and ratchets and a 5' long cheater bar, and I can't budge the mounting bolts on the front of the leaf spring (not the shackle end). It's one bolt through the mounting perch and spring, about 3/4" in size and is rusted into what looks like one solid piece. What is the best way of getting the spring out WITHOUT screwing up the spring or the mounting perch? Thanks for any suggestions.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 03-20-2005, 11:25 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
get out the Mexican fire wrench. you know, professor blue-tip. most likely the bolt is rusted & froze to the steel sleeve in the middle of the rubber bushing. the bad thing is you will need to replace the bushings. but they are probably bad anyway.
good luck
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
