03-21-2005, 12:28 AM | #1 |
hard to start
undefinedundefined
I have a 72 with the 250 6cyl. After it sits for a few days it is hard to start. Once it starts it runs fine. Do I need distributor cap and rotor? Points? Or is it a fuel problem? Anyhelp would be great. |
03-21-2005, 12:59 AM | #2 |
Probably needs a choke adjustment.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
03-21-2005, 01:03 AM | #3 |
Still drivin' a Rat Rod
Most likey a fuel thing.How hard is it to get it fired up? I mean a dozen pumps or dump gas in the carb hard to start?
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
03-21-2005, 02:32 PM | #4 |
hard to start
Lots of pumping the gas pedal and turning over the starter
03-21-2005, 02:40 PM | #5 |
Definite fuel problem. Start w/ the carb and make sure that the fuel level in the fuel bowl is correct. Sounds like it may be set low. Also wouldn't be a bad idea to replace the float valve and accelerator pump diaphragm. Replacing the fuel pump will also help. You current one may be allowing fuel to gravity drain back down from the carb making it work to get fuel after it sits for a couple of days. i.e, carb rebuild, new fuel pump, check that all connections are tight and she should fire right up.
1969 Chevy K20 Fleetside 1979 Chevy K10 "ROBAHOR" (Rusted Out Beyond All Hope Of Repair) |
03-21-2005, 11:50 PM | #6 |
Where's my beer?
once it starts it runs fine, so does it restart fine if it's warm? If so, then your choke definitely needs some help.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
03-21-2005, 11:59 PM | #7 |
your carb prolly needs a good rebuild it sounds like it lets the fuel drain off after setting for an extended period. do this and a tune up if you havent done one in a while and you be happy with the results 250's are great engines, mine that I got from Txfirefighter runs like a well oiled sewing machine just as smooth as can be.
2004 Extended cab LS silverado 2001 Buick Lesabre 1968 Chevy Custom 10 LWB Anniversery model 2008 crew cab lt (rolling on dubs) "The nice part about living in a small town is when you don't know what you're doing, someone else always does" |
03-22-2005, 10:48 AM | #8 |
Hard to start
Thanks for all the imput guys! The truck stars right up after its warm. So I guess it's a choke problem? I got this truck from kansas. the under carrige is filthy, so it probably ran around on gravel roads. I'll do the fuel pump, fuel filter then check the choke. I'm new to the message board,and have some questions about my truck. Hopefully I can write them done without sounding to much like an idiot.
thanks again. |
03-22-2005, 01:59 PM | #9 |
Where's my beer?
When you first get in, put the gas pedal to the floor, then check to see if the choke plate is closed off. That should have closed it off. If not, then your choke isn't working. After you get it started then the plate should gradually open to straight up and down, once it's warm.
03-22-2005, 08:58 PM | #10 |
Franko72
Install a manual choke cable and be done with it.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
03-22-2005, 09:08 PM | #11 |
All Go, No Show
ditto on what Franko said
69 LWB Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI. |
03-22-2005, 11:18 PM | #12 |
The LuvShack Garage
MOST OF MY STUFF IS NEW AND IT DOES THIS VERY THING, I'LL CHECK THE CHOKE
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
