Old 03-21-2005, 04:01 AM   #1
jesse977
jesse977's Avatar
How about pics of "regular" engines
Im looking for some pics of regular everyday engins...no fancy show engins that are all billet and crome please.
jesse977 is offline   Reply With Quote
Old 03-22-2005, 09:41 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Here are a couple that I have.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-22-2005, 10:38 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
2.........
Old 03-22-2005, 10:51 AM   #4
1Ton
1Ton's Avatar
Engine
79 Chevy 3/4ton 400ci All original 18,000miles
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 03-22-2005, 11:36 AM   #5
demi
demi's Avatar
Here's another.
demi is offline   Reply With Quote
Old 03-22-2005, 12:25 PM   #6
oldraven
oldraven's Avatar
The 383 with Propane setup.
'86 C10 regular cab, 383 on propane www.cardomain.com/id/doasa
'87 TurboCoupe 2.3Turbo intercooled 5-spd
www.cardomain.com/id/oldraven
'93 Jeep Grand Cherokee 4.0L
oldraven is offline   Reply With Quote
Old 03-22-2005, 02:56 PM   #7
'70_402
'70_402's Avatar
man demi, that thing is awsome... by far the cleanest engine i have ever seen in stock form.... wow i am spechless.. is that yours...
'70_402 is offline   Reply With Quote
Old 03-22-2005, 03:48 PM   #8
demi
demi's Avatar
Thanks 70'_402. I finally got her back on the road, and it feels good to be driving her again. I did spend alot of time cleaning and detailing the engine compartment. Soon I'll be installing the Q-jet and some small oem items to make it complete.
demi
Old 03-22-2005, 07:38 PM   #9
Here is 98,000 of regular. Only changes was adding an HEI and cutting off the bent snorkel.
Old 03-23-2005, 05:01 PM   #10
bodydropped
i'll get a pic of mine only changes i got is chrome valve covers a holley and a intake and a k&n air cleaner and a optima
bodydropped is offline   Reply With Quote
Old 03-24-2005, 05:24 PM   #11
bc gman
71 bb longhorn
71-402
71 2500 Gmc longhorn with a 402 turbo 400.
09 F150 Supercrew 4x4
05 Mazda 6 sport
accept that somedays you are the statue
and somedays you are the pigeon.
bc gman is offline   Reply With Quote
Old 03-24-2005, 07:18 PM   #12
patgizz
patgizz's Avatar
76 350 with valve cover and coolant neck leaks, but runs like new even with a hillbillied up q-junk on it.
patgizz is offline   Reply With Quote
Old 03-29-2005, 02:13 AM   #13
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
The old 350 …then the new 454HO in my 78’ K10.
Not exactly a daily driver but not show quality either. (Serpentine belt conversion on both engines)
DirtyLarry is offline   Reply With Quote
Old 03-29-2005, 05:16 AM   #14
Kevin45
Kevin45's Avatar
My '74, .030 350 that is going into my '93 daily driver.
Kevin
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
Old 03-29-2005, 09:12 AM   #15
arkracing
Weekend Warrior
Kevin -
is that the harmonic balancer that came off of that motor? - just curious cause it looks more like a 305 balancer than a 350.
besides looks like you did a pretty sweet job on the motor and used all new hardware and stuff (ARP headbolts?) why not go with a new balancer?
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 04-02-2005, 09:03 AM   #16
Kevin45
Kevin45's Avatar
That's the balancer that came off of it. I am considering a new one though as the rubber is cracked pretty good and don't want to take any chances. And yes the headbolts are new ARP. All the externals are ARP stainless. I don't want any rust if I can help it. Now I'm just waiting on a serpentine belt system to arrive so I can get that on. After that then I should be good to go to get everything into the truck. Just in time for warm weather cruising. WhooHoo!!!!!
Kevin
Old 04-05-2005, 04:49 AM   #17
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Is that the TBI setup on the 355? Cant really tell but I'm pretty sure it is, and the knock sensor in the block. Did you put a better camshaft or anything like that in the 355? I know there isn't much room to play with TBI and it being a daily driver but was curious anyway. Isn't the 93 your teal green short bed?
Looking pretty good
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-09-2005, 04:47 PM   #18
68gmcdually
68gmcdually's Avatar
Here a couple of pics of mine "in progress".
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 04-12-2005, 01:41 AM   #19
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Here you go.
Engine
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 04-12-2005, 02:39 PM   #20
Kevin45
Kevin45's Avatar
Yes the '93 is my Teal green one. And it is a TBI setup. It has a Holley Pro-jection intake and a Holley 2 bbl.throttle body with 2" bores rated at 670 cfm. Everything was rebuilt before I bought the truck and had all new internals. The only thing is the guy I bought it off of could not locate the paper showing the cam size. It is a Comp cam though. Heads were all redone and had larger valves 2.02/1.60 with roller rockers, screw in studs, and cut for teflon valve seals. I just received the brackets for the serpentine belt system yesterday, so I have to get that cleaned up and mounted, then into the truck it goes. So hopefully in a couple of weeks I will have it done. Then I have to concentrate on getting it lowered down.
Kevin
Old 04-13-2005, 08:58 PM   #21
68gmcdually
Here is a better one of mine, which I might add is getting real close to running again.
James Bellwood
