03-21-2005, 09:20 PM | #1 |
Uncle H. is this cartoon
2wd "cheap" lift; 1 ton springs or coil spring spacer?
I might be getting a 1993 C1500 soon and would like to raise the front end to level the truck. I'm considering 1 1/4" Daystar coil spacers or buying new 3/4 or 1 ton front springs. (I can't afford a $600 3" lift kit) The front springs on the truck I've seen look like they've sagged a bit. (maybe up to an inch) I hear both will cause more ball joint and tie rod wear. What do y'all think would be better? Has anyone here been in a truck with coil spring spacers? Will the 1/2 ton springs feel like the 1 tons after the spacer anyway? Are there any advantages of having a 1/2 ton spring and coil spacer? (besides a small amount of extra lift)
Any advice would be appreciated! |
03-22-2005, 08:45 AM | #2 |
I would advise not going to a 1 ton coil unless you are aways loaded. They are way too tough. I put 1 ton springs in my 84 and it's way to hard. 3/4 ton springs will be much better. Just stop by a spring shop and they wil get you taller spring with a decent spring rate. When you there you will need to get them compressed.
Good Luck Good to see another Ontario Local here.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-22-2005, 04:49 PM | #3 |
Uxbridge, I have cousins there!
I thought all 1/2 ton truck coil springs were the same height as other 1/2 ton coils. Are there actually taller 1/2 ton stock springs? (even 1/4" taller?) It'd be nice to get a spring that's an inch (or more) taller than a stock truck. I saw a truck book and it shows 3/4 ton and 1 ton front coils are both rated at a 4100 lb spring capacity, so I thought that meant they were the same spring. So are changing the springs a better idea than 1 1/4" lift coil spacers? (I want the ground clearance but can't afford a 4x4) |
03-22-2005, 04:51 PM | #4 |
BTW I'm tired of winter too; I got sick of the cold back in early October 2004!
03-22-2005, 11:23 PM | #5 |
The spring shops have coils lined up and the have weight rating for them all . you could just find a taller spring with a similar spring rate.
I would try the coil spring spacers. You might have to get the spring compressed so they will go back into the spring pocket. But that would be what I would try first. I am also into the lifting 2 WD trucks. Cheeper on gas less parts to break and more pratical for the roads around here. I am going to pull the 1 ton springs and try a spacer and the old 3/4 ton springs.
