03-21-2005, 09:34 PM | #1 |
need help fast
ok guys i have a 81 chev 1/2 ton 4x4 and i did a stupid thing today ,i went and broe the top of the bellhousing off putting in a new 350,BUT this truck has a new process 203 transfer case and I have a 3 speed automatic transmission.and was wondering what tranmissions will work with this transfer case will a th 350 be the only kind or can I cut the tail shaft on a car or truck th 350 and still have it hook up the same with no other mods PLEASE help Im stranded.
gm's are #1 1967 chevrolet short step 1988 chev 4x4 1/2 ton 1989 gmc 1/2 ton 1991 chev 1/2 ton 4x4 1993 Jeep grand cherokee 4x4 And yes a 94 Ford Mustang. |
03-21-2005, 09:41 PM | #2 |
Gentleman Jim Driver
The transmission output shaft is different between a 4x4 truck and a 2wd (of any kind, car or truck, short, long, or intermediate tailshaft).
What exactly broke?
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
03-21-2005, 10:43 PM | #3 |
I busted the top right off the bellhousing and to get it fixed is gonna be more than another tranny.
I know that a car or truck tranny th-350 will fit a new process 208 all aluminun transfer case if you pull off the tail shaft and cut the out put shaft down I have done this and it works great they are the same spline and all just that the 203 is a 4 piece transfer case front 2 halves are cast and rear 2 pieces are aluminum and I think it might have a different spline and everything so I think I might be stuck with 1 tranny option but not sure what will bolt up to the 203.
03-25-2005, 08:34 PM | #4 |
Sorry,Pal.It's gonna be a 4wd th350 or a complete tranny/transfer case swap.
I hate to admit it,being as trannys are my living,but I did this same thing a couple of years ago.Plain and simple,I got sidetracked and forgot to pull 1 bolt,it was of the top 2.The engine pulled right out,with about a 6" chunk of transmission.Not good,and you can only hope you were alone when it happened. |
