Old 03-21-2005, 10:14 PM   #1
davidh
davidh's Avatar
dual tank problems
Every one of these trucks I"ve owned has had a damn problem with not switching gas tanks. My 77 3/4 quit on me and I had to crawl under and by pass the valve, my 81 4x4 does nothing when I hit the tank switch, just to name a few right off, What's the deal??
davidh is offline   Reply With Quote
Old 03-21-2005, 10:59 PM   #2
dswancutt
I have never had a problem with my 78 K-10 in the 10 years that I have owned it, and those included years where I couldn't afford the most basic of mantenance. How often did you use the switch. I switched tanks at least one time every week. My theory, for whatever it's worth, is if the tanks aren't switched on a regular basis, they jam up. I may be full of it, but you would think as much as mine where used, they would fail.
Doug
dswancutt is offline   Reply With Quote
Old 03-21-2005, 11:05 PM   #3
Sailor77
I have had some work and some not. More than not it is the switch in the dash that is the problem.
Sailor77 is offline   Reply With Quote
Old 03-21-2005, 11:07 PM   #4
Russell
Professional Grade
Russell's Avatar
I have yet to own a truck where the tank switch worked. And I've had a few, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-22-2005, 12:12 AM   #5
Brad_Olson
Active Member
Brad_Olson's Avatar
So is an effective solution the replacement of the switch with one of higher quality from an electronics store? Or is there something special about the factory switch? My '78 C10 no longer has dual tanks but I suppose I could swap the switch into my '86 K10 to see if that helps with the selector valve problems I described in a post earlier tonight...but something tells me I'll wind up saying "Screw it" and plumbing the passenger-side tank as the full-time supply.
Brad
Brad_Olson is offline   Reply With Quote
Old 03-22-2005, 12:45 AM   #6
BabyBlue
The Peacemaker
BabyBlue's Avatar
I'd check the fuse before you do anything first, if you hold the button too long it'll fry that fuse and I found that out with my white stepside. Check that and then replace the switch (I think it's like $8.95), and thats really what goes wrong with them. Never heard of what dswancutt says but I can see how something can happen after a long period of time, like 6 months +.
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 03-22-2005, 01:28 AM   #7
86k10
If you don't use them on a regular basis they will get sticky and not work. I always switch back and forth and never just fill one tank and have never had a problem.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 03-22-2005, 01:53 PM   #8
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Here's a write up I did before on this subject. Hope this helps. Does your gauge move when you switch the tanks? Have you been kicking or moving anything near your fuse block panel? Just a few questions to help diagnose.
Now here's a couple ideas:
On your interior valve switch replace it. To me it sounds like you have a bad switch. I got mine with cover for like $10 from the dealer. Don't use the Auto Zone stuff. The dealer is a couple bucks more but why waste on something that isn't to GM specs? To take off the switch and cover the 2 nuts have to be taken off the rear of the cover behind the dash. Best way is to take out the ash tray and it's much eaier to get to then. Don't use the Auto Zone stuff. The dealer is a couple bucks more but why waste on something that isn't to GM specs? While you're there with the plug off let's see if we're getting power to where it needs to be.
From the 3 o'clock position this is #1 wire then so on till #5 for reference.
#1- Ignition wire (pink w/ black stripe)
#2- Valve wire (lt. green)
#3- Tank Aux. (lt. blue)
#4- Gauge (tan)
#5- Tank Main (tan w/ white)
#6- Not used
With the ignition on you should get power with the #1 slot. If not check the pink w/black wire by following it to the fuse panel. Mine was connected with a male spade connector to a IGN slot. This way it's only powered when ignition is on (neing not running). Also you should have a light when testing for the #4 gauge as well (assuming it the #1 is hot).
If this doesn't solve it then take a test light to your fuel valve itself. It is located on the passenger side close to where the cab and bed meet. There are 3 different setups on the valve. They are 3 ports (fuel) 1 wire, 6 ports 1 wire (mine) and 6 ports 6? wires. You need to see which one this is. On the 3 & 6 ports with 1 wire, the green wire, attaches to a bolt coming from the valve itself. This is what powers the valve to flip from the one tank sending hose to another. When you have the selector valve on the left side (with ignition switch on and for safety engine not running and emergency brake on) the green wire will have power (where test light comes in). When you have it on the right side of the switch the wire will have no power. This is why I like to run on my right tank more often than my left. Now if you don't have any power to that switch under the bed, you need to backtrack (next section). If you do have power then you need to test the valve itself. With the ignition on engine not running and emergency brake on (safety first) take the green wire with connector to the "bolt" that is the connection on the valve itself. As long as you have power (with the interior switch flipped to the left side) you should hear the valve turn to the left tank. It sounds like a "click" almost. If you have power to the green wire but the valve is not changing tanks this is your problem. Replace the valve (I got mine for $70 from a AC Delco parts warehouse) and while you're there replace all the fuel lines as well. It's cheap insurance. Just make sure to label the hoses so you know which goes back on where. With 6 hoses on mine it was a job to make sure everything was on right.
On the firewall driver side look for a 4 wire harness with a bulk connector (looks like a connector that has a rubber boot) It will have 2 tan wires a green and a lt blue wire. This is where the tanks and selector valve wire come from the interior switch. If this is tight and no corrosion then we'll need to rethink this. Hopefully this works.
If you have a 6 wire then let me know and I'll try to find a spec for that then. I have't messed with that wire harness yet at the tank selector valve itself.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
