Life, Be In It.....
![]() Join Date: Oct 2003
Has anyone relocated their battery, somewhere other than the engine compartment or bed? I was thinking about putting under the bed somewhere and wonder what type of braket I should use.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
Here's my solution. Fabricated batt box located right front of box. Took a lot of figuring, but will work.
someday it will be done!
I've seen a bat.box that will mount up high on the frame.If you need to get at it,it can be lowered down for easier removal...early classics mebbe?Sorry I don't know where,but they are out there.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
CPP sells them.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Alot of street rod retailers sell trick things for this. Aren't you supposed to use a sealed battery because of the exhaust gasses???
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Mike
Full size ford vans,that have aux batteries,have a box mounted on the passenger side frame rail.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
I put my battery under the bed. I made a battery holder out of steel.
Resident Young Old Dude !
Here is a couple, The one is C.C.P.s
The only thing I have a problem with???? We do what we can to keep our truck theft proof as much as possible.... With one of these, All someone has to do is look under the truck and unhook the Battery,, Then he's in it, it's Hot Wired and Gone.. You would need to build something around the cable so they couldn't be taken off or cut.. |
Got Light Emitting Diode?
couldnt you put a dry cell (optima) under your seat? just i thought. id never do it though
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
I used the CCP bracket with a Optima Red Top battery. Behind the cab on the frame on the passenger side. Works great.
1972 Blazer body...need to get a thread started for the rest of the story |
Ummm I dont see how moving the battery under the truck would make it easire to steel ? Would having it under the hood not be easier ?
#12 | |
While under the hood and the hood not secured down, A thief can pop the hood, cut the alarm siren wire and get into the vehicle to start his dirty work. and if you have a starter interupt, you just run a jumper wire from the battery to the starter solenoid. Jump in the vehicle with a starter switch, unplug the wires from the one in the truck and plug them into yours which you have the key for, and again you're off.. ( I went out a few nights with a repo man friend) People would do whatever they could to keep him from picking up their cars, but he had a way around almost everything. Then Again,,,,, You can also Hot Wire a vehicle from underneath at the starter with a remote starter switch!!!! (This is where lowered vehicles are nice.) So I guess, where does it begin, and where does it end ??? A guy can really get carried away Huh? But,,,, I didn't say they're not cool, they would really help to clean up the underhood area.... And I'm contemplating a more secure installation where the battery post would be protected from easy access... |
#13 | |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#14 |
got boost?
i mounted a red top optima inverted behind the right rear tire under the bed
no batt. box needed as it fits between the two bed "ribs" nicely. i just bent up an aluminum brackett that fits between the two ribs & across the batt between the posts & attached to the ribs with bolts.this requires drilling access holes in the ribs for installing nuts but, it's been there for three years with no probs. 383 stroker;why did you put it on the left side?
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" ![]() |
