03-22-2005, 10:11 AM | #1 |
Certified Truck Nut
anyone wanna take a guess at mpg?
82 GMC Sierra Classic
LWB 2wd 350 .040 over w/flattops 487 heads, mild cleanup portwork Summit 1103 cam 272/282 214/224@ .050 .442/.465 Torker intake 600 VS Holley TH350 10 bolt rear 3.73s 225/70/15s truck isnt all that heavy, weighed about 4500 with 3 people in it, all in the 200-250lb range. whadda yall think ill be getting, 10ish? later Dan
1982 GMC Sierra Classic 1500 Longbed 350, TH350, 3.73 10 bolt soon to be slammed |
03-22-2005, 10:13 AM | #2 |
North Coast, baby!
Bullseye!
Brad 79 Scottsdale C20 350/350 3.73's Still running full CA smog gear! |
03-22-2005, 10:18 AM | #3 |
Right turn Clyde
Thats my guesstament
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
03-22-2005, 02:21 PM | #4 |
20 gal X $2.00/gal @ 10 MPG = $$$$$$$$$
Mine gets 14 and I only drive it maybe twice a month now.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
03-22-2005, 03:52 PM | #5 |
Chevys Kick A$$
Yeah, I would also have to say right around 10 mpg depending on how much of a lead foot you got.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
03-23-2005, 01:53 AM | #6 |
Isn't the torker a single plane?
03-23-2005, 12:48 PM | #7 |
Certified Truck Nut
10mpg
yes the torker is single plane, its not a great design, and will be replaced soon enough. later Dan
03-24-2005, 03:07 AM | #8 |
When I was looking for an intake someone offered a torker very cheap. My motor was completley stock so...That really wasn't the right one for me.
I noticed you did have some work in the motor. How is the low end torque with your setup? |
03-24-2005, 10:20 AM | #9 |
Yup, 10 mpg is about all you'll get. 350, 3.73s, no overdrive-- I wouldn't expect any more than that.
I only get 12.5 on average, 14 max out of the 350/TH700R4/3.73 combo in my 2WD, 5,400-lb. Suburban. I do get 10 when towing, though...
Semper Paratus |
03-24-2005, 04:28 PM | #10 |
I have about the same setup, with stock 882 heads and the 1104 cam. 700R4, and 3.73s and I'm doing good to get 12 with it. It does have a small leak somewhere in the tank, but I cant track it down.....So good luck trying to get more than 8-10 with the TH350.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
03-24-2005, 05:18 PM | #11 | |
I would guess that a new full size truck with a V8 probably doesn't get but around 16 or 17 mpg. |
03-27-2005, 01:34 AM | #12 |
A guy at work has a new hemi dodge quad cab 1500, with the 20's and all and it gets barely 13.5........with a 5 spd automatic!!!!
03-27-2005, 02:17 AM | #13 |
I must be kind of lucky then. I just recently converted my 74 C20 from a 4 speed manual to 4 speed auto and during the warm weather It gets in the 18 to 20 range. Yeh I know you are all saying but I'm not kidding. Here is the build spec. It's nothing great but it will keep up with most new ones that's the nicest part.
350 .060 flat tops 993 heads Cam: Meiling 278 int. 288 exh. 0.50 duration 204int. 214 exh. Torker II intake Q-Jet carb 700R4 14 Bolt FF 4.10 Gov Lock |
03-27-2005, 02:26 AM | #14 | |
mileage
i figure mine will get about 10 mpg when i am done also,,,but i have been thinking seriously about having the word's my dad hand painted with a paint brush on his 50's gmc air brushed on my tailgate...( don't laugh,i'm paid for) white paint hand painted on the old thing and use to drive me to school in it!!! lolol.. but how true it is... |
