Old 03-22-2005, 11:51 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Need a pic showing kick panel carpeting
I am ready to start on the carpeting for my kick panels. Can someone post a couple pics showing carpet in this area. I am interested in seeing how the vent opening is finished and also how close the carpet comes to the door seal.
Here is that area insulated and ready to have the vent opening cut before I start the carpet.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-22-2005, 12:12 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Mine go right up to the door seal.The area aroung the vent is finished with that edgeing stuff.I can take some pic's if you want YJ.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 03-22-2005, 12:27 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
If it isn't much trouble, I would like to see some pics. Thanks.
Old 03-22-2005, 12:31 PM   #4
BobbyK
BobbyK's Avatar
ok,I'll be a few minutes.
Old 03-22-2005, 12:49 PM   #5
BobbyK
BobbyK's Avatar
Here you TJ.I got these from the truck and car shop.
http://truckandcarshop.com/
Old 03-22-2005, 12:58 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Thanks for the pics.
The carpet I am using will be cut to fit by me rather than the pre-made style like Bob is using. I think I will try to cut it so I can fit the carpet under the door seal. Has anyone done it that way? If so, would like to see pics.
Old 03-22-2005, 01:03 PM   #7
70c10
67-72 Addict!
70c10's Avatar
I recently installed the same ones in my dad's truck and like BobbyK, they interfere with the air vent opening all the way. I made my own for my 70' to alleviate that problem but when I installed my kickpanel pods I lost the use of the vents anyway.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
