Old 03-22-2005, 05:37 PM   #1
arkracing
Weekend Warrior
Redrilling Axles????
Anyone have this done? what did it cost you?
I have a '69 6lug rear and don't really want to spend $300 for ECE's rear axles and then have to buy drums on top of that.
and there aren't any good 5lugs in the NE that i know of...i've called abunch of yards/newspaper ads with no luck
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-22-2005, 05:41 PM   #2
jhow66
jhow66's Avatar
Would there be enough room for the new holes? Any machine can drill them for you if there is room.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-22-2005, 07:00 PM   #3
mooneyes
mooneyes's Avatar
...not enough room unless you welded up the other holes first...i redrilled my 5 on 5 bolt to a car pattern 5 on 43/4..but i wanted to do my 6 bolts cause my tires stick out a bit and the 6 bolt rear is narrower
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 03-22-2005, 08:33 PM   #4
REPO1
Shortbox wanna-be.
REPO1's Avatar
I had it done with no problems. You have to weld up 2 holes for sure. I just took mine to a local machine shop and had them do it. You also have to have the inside hub machined down so the '72 style 11x2 drums will fit over it as it has a much smaller hole.
They charged me $100 cash to do mine. (Canadian $$$)
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 03-22-2005, 08:55 PM   #5
Orange70chevy
Orange70chevy's Avatar
When I was going to change to a five lug. None of the machine shop down here would do that they all said it was a safety issue?
Orange70chevy is offline   Reply With Quote
Old 03-31-2005, 12:58 AM   #6
arkracing
Weekend Warrior
welding the holes isn't the problem, and having a shop do the redrilling isn't a problem either..i know several guys who have bridgports and milling machines @ thier personal shops..so no need to worry about "liability" with having a shop do it.
and machining the end should be a problem either.
will the '72 11"x2" drums fit over my stock '69 backing plates/shoes? or does that all have to be changed as well?
-'66 C10 Suburban
Old 03-31-2005, 01:15 AM   #7
REPO1
Shortbox wanna-be.
REPO1's Avatar
Yes. I installed '72 (11X2) drums onto my '70 with no problems. I just welded up the axle holes and had them redrilled. They slipped right onto the '70 backing plates.
Old 03-31-2005, 09:37 AM   #8
arkracing
Weekend Warrior
sweet - thanks for the info
-'66 C10 Suburban
Old 03-31-2005, 12:36 PM   #9
Low69CST
I didn't have any luck getting local machine shops to do it. Sent mine to Moser Engineering. No problems so far.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
