Old 03-23-2005, 12:12 AM   #1
kxmotox247
kxmotox247's Avatar
Mud-Terrain tires - BFG's...anyone own them?
If so, I have a couple questions for you.
How loud are they on the street? I love the way they look on trucks. I can settle for a little less mileage out of them but how bad is it really?
I got 40,000 + out of the last set of BFG all-terrains.
Any other drawbacks? I'd like to put them on my 2004 4x4.
Thanks!
kxmotox247 is offline   Reply With Quote
Old 03-23-2005, 01:55 AM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I love them and there pretty damn quite on my Blazer. Kick up he*lla mud and are pretty punture resistant. I have the 35"x12.50"x15" and I love them.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-23-2005, 02:12 AM   #3
4x4Poet
I have Moab Edition BFG MTs on my FJ40. They do make some decent noise, mostly at boulevard speeds that let the side lugs strike the pavement. At highway speeds, the super aerodynamic qualities of my sleek, nascar drafting, jelly-bean styled Cruiser help the wind make more noise than the tires. I'm convinced that the greater rotational centrifugal force at the tires makes the tread ride mostly on the smaller center lugs with the side lugs making less contact than at slower speeds. IOW, the side lugs contribute most to the hum if given the chance to strike the pavement under a full contact patch. I also run them @50psi on road for best mileage and longevity. The higher pressure reduces the noise, some. No worries of crowning since they're big radials on a 4000lb truck.
I've heard that the more recent versions of BFG's MTs make less noise due to a slight tread redesign commensurate with recent high tech advances. The newer MTs also have the functional and cool side biter tread that previous editions didn't have. In any case, I say sound proof your truck so you can have your mud cake and eat it too.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-23-2005, 03:03 AM   #4
Hoods69BadBowTie
Chevys Kick A$$
50 PSI, is that a little high or no? Are they easier to pop like this or no?
-Later
-LATER
Old 03-23-2005, 09:05 AM   #5
kxmotox247
kxmotox247's Avatar
50 psi just on the street, right?
Thanks for replying guys...
Hoods69...where are you at in MT? I spent a few weeks riding dirt bikes at a place called pipestone just east of Butte. Ever been there? I'm pretty sure you can take 4x4's there.
Old 03-23-2005, 09:33 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I ahd the 35" MTs on an 85 K5, sold it w/ 20K miles and the tread still looked new. Saw the K5 several years later and the tires were still going strong.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-25-2005, 04:14 PM   #7
Devil'S Ride
I run the M/T's an love em. They are very quiet, I also had em siped when I bought em. I punched a 2" hole in one, but thats cause i ran over a tree....I drive the hell outta the tires, an have never had any problems with em. They clean well, grip well in mud, sand dirt, snow, dry road or wet road. if you go that route, ask about an insurance policy from the place puttin the tires on. I bought mine from America's Tire company, an paid an extra 21$ a tire for insurance. When I punched that hole, I took the tire to the shop, said I want a new one. I got a brand new tire, siped mounted balanced, everything, for 21$ for the new insurance policy.
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 03-28-2005, 07:54 AM   #8
4x4Poet
-Later
Naw, these moabs are definitely built for 50psi all day long. Pop in what way? As in too high pressure? No way. Because they are large radials, the carcass still flexes. I don't notice much difference in ride smoothness. Just crisper handling, especially at high speed. But after thinking about it, I don't know what regular new MTs have as a max load @ inflation, so I expect my experience doesn't matter. My mistake to have brought up the psi. Noise is what was asked about. I only talked max inflation with regards to keeping the side lugs from striking the pavement in a noisy fashion which still should apply. Both the ATs and MTs are great tires, in any case.
Yep. I said "on-road" above. I'll drop 'em to 15 psi or so off-road. Less on soft, hazard-free snow off road.
Old 03-28-2005, 02:36 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Dam, I missed where you said (Yep. I said "on-road" above.) I was thinking you meant when you were off-roading you had them at 50 PSI. My mistake.
-Later
-LATER
Old 03-30-2005, 02:50 PM   #10
chevyfarmer
chevyfarmer's Avatar
good infornmation everyone.
i have had both AT & MT BFG's in the 31x10.5x15 size.
the AT's were silent, the MT's were louder but very tolerable
the AT's lasted many many many more miles than the MT's
just my .02
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 03-30-2005, 09:21 PM   #11
cleatussnow
cleatussnow's Avatar
I have MT's on both of my trucks now, my DD and my GMC. I had AT's on my last truck and they had gone about 60K with approx 10k to go when I sold it. My GMC had, what the previous owner called 70K, on them but I could almost see the belts.
As for the noise issue, on all of my trucks the exhaust was much louder than the tires...
Cleatus.
"What we are dealin' with here is a complete lack of respect for the law...." Beuford T. Justice
cleatussnow is offline   Reply With Quote
Old 03-31-2005, 07:31 AM   #12
Mudder
Mudder's Avatar
I don't like the way they throw rocks........
Mudder is offline   Reply With Quote
Old 03-31-2005, 09:34 AM   #13
kxmotox247
kxmotox247's Avatar
My All-Terrain's held more rocks than my driveway. Then at about 25-30 mph....Lookout!
Old 03-31-2005, 05:08 PM   #14
turkeyguide
I love mine. I had a set of 265/75R16's and got about 45 or 50k miles out of them. This time I went with 285/75R16's. They are fairly quiet and ride good. The 265's drive like factory tires, but the 285's tend to wander back and forth a little. When it comes time to go off-road, I hardly ever even need 4wd any more. They will go anywhere. My truck is a '98 Z-71 SB regular cab 5 speed with a 5.7 liter and locking diff.
WTB: 71 or 72 4x4
turkeyguide is offline   Reply With Quote
Old 03-31-2005, 05:13 PM   #15
kxmotox247
kxmotox247's Avatar
Wow... 45 to 50K miles is a lot of miles for a set of radial mud tires.
That's a pretty good report.
Old 03-31-2005, 09:43 PM   #16
Bradleyworld
BFG MTs
I've ran them on my last 4 trucks. I really don't like the new design though. Kinda ruins the look of the sidewall IMHO, and makes them tougher to clean and dress. I recently replaced my old BFGs with some Coopers that look almost identical than the "old" MTs. Not sure how long they'll wear but they were $480 cheaper than BFGs and so far have been great in the snow.
Bradleyworld
Bradleyworld is offline   Reply With Quote
Old 04-02-2005, 08:31 PM   #17
6 2 Carl
6 2 Carl's Avatar
Originally Posted by Devil'S Ride
I I also had em siped when I bought em. .
How are the siped tires holding up? Will you be siping the tires again as they wear? How much of the tread did you sipe? How much better are the siped tires in the winter? I have been running BFG AT for years, mainly for the winter performace. I want to try Mud Terrains, but I don't want to give up any traction in the winter. A siped MT may just be what I need.
Carl
6 2 Carl is offline   Reply With Quote
Old 04-03-2005, 09:07 PM   #18
uncle_handsome
Uncle H. is this cartoon
uncle_handsome's Avatar
What size of a/t's?
uncle_handsome is offline   Reply With Quote
