Old 03-23-2005, 12:31 AM   #1
bagged01extcab
difference between cab & chassis and dually?
I just bought an 85 4 door crew cab 1 ton with a work bed on it, and was trying to determine if it was a dually or a cab & chassis. How can I tell the difference? The brake hubs are right up next to the spring perchs, and It looks like the outer wheels stick out past the rest of the body, but I'm still unsure! Maybe someone has some deminsions or something! Any help is appreciated!
Trey Oney
bagged01extcab is offline   Reply With Quote
Old 04-21-2005, 06:59 PM   #2
loweredd
www.loweredd.com
loweredd's Avatar
Call a Chevy dealer and have them run the VIN. That will tell you.
loweredd is offline   Reply With Quote
Old 04-21-2005, 08:56 PM   #3
badone07
Project 2 Resume
badone07's Avatar
I have an 84 crewcab cab & chassis with dually set up. Sounds like you have the same, by your discription. I looked up VIN codes and didn't say either way within our years. Anyway, the measurement between the inner wheels is about 45 inches. Mine was a stake bed that I replaced with a fleetside LWB bed. Had to put 2" lift blocks between springs and rear for wheel well clearance, instead of minitubs. Outter wheel treads are completely within the wheelwells. A couple of pics here... http://207.44.196.117/vboard/showthread.php3?t=126946
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 05-01-2005, 02:43 AM   #4
1FaastC10
1FaastC10's Avatar
C&C will have a 14 bolt Full Floater (extra narrow) so it will be just as wide as the front axle. a Dually pickup will have a Dana 70 in it, and will be considerably wider than the front axle. the easiest way to identify the axles are the cover bolts, the 14 bolt will obviously have 14, and the Dana 70 will have 10. also, the 14 bolt has a bolt in pinion housing.
1FaastC10 is offline   Reply With Quote
