Old 03-23-2005, 01:20 PM   #1
Deelli
Installing Windshield in 1986 Silverado
I've had the cab totally apart to repaint and have a new seal for the windshield. I've installed the seal and the corners seem to not lay down flat, I'am hoping that the windshield will push out enought to make the fit good. Just wanted some feedback or suggestions/advice on installation. I did not use any lube on the seal when I mounted it to the frame, should I use lube before I install the glass? Thanks in advance for any help
1974 911 Carrera 3.0 (Turbo body)
1980 C10 LWB (soon to have 86 cab &350 TBI 700R4)
1992 Toyota Camry XLE
1995 BMW 740IL
1997 1500 4.3
1998 Toyota Camry XLE
Deelli is offline   Reply With Quote
Old 03-24-2005, 04:43 AM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
If I can remember correctly:
When I had my windshield replaced, the seal properly seated after the glass was installed. They sprayed on a lube prior to installing the glass. They did have to wrestle with the rubber seal for a bit to get it to seat correctly. Once they installed the glass, they went around the seal with a black sealer (between the underside of the seal and frame). They didn't use any lube between the seal and the frame.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
