03-23-2005, 05:48 PM | #1 |
Shoulder belts.
Will the shoulder belts from a 73-87 series pickup fit into a 67-72 without much trouble? We've finished my 69 and are working on my 17-year-old son's 67 and his mother would be happier if the 67 had shoulder belts in it. She doesn't seem to care about the 69 since I drive it....
03-23-2005, 06:05 PM | #2 | |
'71 GMC 350 bored, cam'd, straight pipes LOOKING FOR A 4x4 redz 1970 K5 "Time has stopped for our classic trucks, and as such maintain nostalgia and simplicity of the vehicles and of an era passed." |
03-23-2005, 08:39 PM | #3 |
I am using the belts out of an S-10 and it is an easy install. The anchor point has to be relocated on the drivers side for the lower but both belts attach to the upper anchor point with no problem. I used a 3"x4" plate with a 1/2"-13 nut welded to it for the lower anchor on the drivers side under the floor for strength. The two center belts mount to the stock locations.
I can post pics tomorrow if no else does. The S-10 belts seem to be a popular choice and I can understand why. Jim |
03-23-2005, 08:54 PM | #4 |
CCRider
The only problem with the S-10 belts is that a lot of junkyards will not sell used seatbelts because of liability reasons...I gave up and just bought some new ones from GMC Paul
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
03-24-2005, 11:30 AM | #5 |
But, will the belts from the full-size 73-87 series bolt right in?
03-24-2005, 02:43 PM | #6 |
You might make them work but the floor pan of the 73+ is quite abit different than the 67/72 because of the side gas tank. The 73 floor has a kickup to provide room for the tank that partially under the cab. There is a reason many people use the S-10 style.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
03-24-2005, 03:51 PM | #7 |
The full size 73 and up seat belts looked too short and I could not find black belts in the trucks. I never measured one as I knew that S-10's had been made to work by board members so that was what I kept looking for.
Jim |
03-24-2005, 05:41 PM | #8 |
Anybody got any pics of the S-10 belts? I would like to see how it mounted up top.
Why do we drive on a parkway and park on a driveway? |
03-24-2005, 08:37 PM | #9 |
Here are a couple of pics. The lower anchor has been moved forward by adding a plate with nut under the floor. The upper part of the belt is fastened to the existing upper 7/16-20 anchor nut. I made a plastic bushing to keep the metal part from rubbing the cab and used a shouldered seat belt bolt to attach it. The upper part has to swivel to work right.
Jim |
03-24-2005, 09:21 PM | #10 |
Its Magically Delicious
what year s-10's ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
03-25-2005, 09:12 PM | #11 |
I got the belts out of a 93 S-10. I think the years to look for were 88 to 93.
Jim |
03-25-2005, 09:26 PM | #12 |
i would pony up and buy new belts. over time seat belts dry rot and will break when they are needed most. sitting in a car or truck for years in a junkyard is very hard on them and weakens them tremendously. if your going to use a junkyard seatbelt ya might as well not use any at all
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-25-2005, 10:19 PM | #13 |
we have a parts s10 if anyone wants a set....
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
03-26-2005, 03:33 AM | #14 |
yes they do fit it requires some small mods at the bottom but they do work i have some out of a 79 in my truck
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
03-26-2005, 04:13 AM | #15 |
ECE sells the shoulder belts and I think they are fairly reasonible.
1972 Blazer body...need to get a thread started for the rest of the story |
03-26-2005, 10:53 AM | #16 |
PROJECT 7DEUCE
I am looking into doing this swap pretty soon.. Jim did you buy your from the j-yard or a vendor??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-26-2005, 11:43 AM | #17 |
I got my from a yard. The belts are excellent, and not weathered since the doors were still on the truck.
Jim |
