Old 03-23-2005, 06:17 PM   #1
69sixpackbee
Power Brake Problem
Heres the scoop:
My '72 has new calipers, rear cylinders, pads...you know, all the stuff. I have a brand new booster an a good master. This problem I am going to describe happened before I swapped the booster out as well. When the engine is cold and fast idling and the truck has been setting for a while, the brakes are nice and "touchy" as in barely any pedal effort to send you through the windshield. After I go a few blocks the brakes need alot more effort to stop. Even when going slow. The engine has 18-20" vacuum when idling warm and has no leaks in the power brake booster because the idle is nice and smoothe all through the pedal travel. This acts like a poor vacuum condition yet the engine has plenty. It is a stock 402. The connection to the vacuum booster is tapped off of the manifold runner behind the carb. This is a Performer dual-plane intake. Should I attach the hose to the carb base instead or what does this sound like?
Thanx!
Bud
69sixpackbee is offline   Reply With Quote
Old 03-23-2005, 06:25 PM   #2
farside847
farside847's Avatar
By chance does it happen when the roads are wet? My brakes grab harder
when it rains and it burns off after a few minutes.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-23-2005, 06:30 PM   #3
69sixpackbee
Nope. No diff.
Old 03-23-2005, 07:08 PM   #4
pjmoreland
pjmoreland's Avatar
I had a problem with my brakes a while ago where the little threaded rod that comes out of the booster and pushes the master cylinder was threaded out too far and wasn't allowing the master cylinder to return all the way back when I wasn't pressing on the brakes. This made it so that the brake shoes weren't allowed to release all the way from the drums when I released the brake pedal. Not sure if this is the same problem you are having.
pjmoreland is offline   Reply With Quote
Old 03-23-2005, 08:42 PM   #5
tom hand
CCRider
tom hand's Avatar
I would check pjmorelands sugguestion....I have had this problem and though the simptoms were not exactly as you discibed it gave me fits till I figured it out....make sure the pedal still has some freeplay when it is warmed up
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 03-23-2005, 08:47 PM   #6
69sixpackbee
I'll check that!
