Old 03-23-2005, 08:21 PM   #1
Tim240Z
Tim240Z's Avatar
Question Diff ratio help (again!)..very confused!!!
OK...everything I've read in my searches on this board says that my 'corporate diff' should be 4.10:1 or lower (up to 5.x by some accounts).
I need to send my PCM for the 99 suburban engine for reprogramming so I checked the diff for accurate ratio.
Here is what I got:
For every one revolution of the wheels, I get about 3.4 revolutions at the driveshaft. Wouldn't that give a 3.x :1 diff ratio?
Anyone have any ideas? I want my PCM to get as accurate a speed signal as possible.
Thanks,
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 03-23-2005, 08:28 PM   #2
cableguy0
y not just pull the cover and count the teeth no other way is truely accurate. its about time for new gear oil anyways especially if it hasnt ever been changed
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-23-2005, 08:48 PM   #3
Tim240Z
Tim240Z's Avatar
Well....I could but I would need to wait for the weekend. I will do that anyways, but I thought I would see what the brain trust here had to say on the subject...
If it was almost 4 turns at the input, I would just assume a 4.1, but it isn't even close....
1972 Suburban C20
Old 03-23-2005, 08:49 PM   #4
Sweet72
Sweet72's Avatar
3.42:1
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-23-2005, 08:53 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you only have one wheel off the ground, you need to turn the wheel 2 turns and count the driveshaft turns.
Old 03-23-2005, 08:54 PM   #6
Tim240Z
Tim240Z's Avatar
Exclamation
Originally Posted by Sweet72
3.42:1
Really!! for the Corporate/Eaton/spicer diff? Everything I have read on here during searches said lower than 4, with a white elephant of 3.9 available back in the days.
I will definitely open the Diff this weekend.....
1972 Suburban C20
Old 03-23-2005, 08:59 PM   #7
Tim240Z
Tim240Z's Avatar
thanks for that tip.....4.1:1
Sorry for the rookie mistake......I'm better than that...really I am
1972 Suburban C20
Old 03-23-2005, 09:16 PM   #8
Tx Firefighter
It's a common mistake.
