Needs a Big Block
63-72 rear step notch pic request
I am about to build a step notch for my 64 , for the front I've done a 1.5 inch drop member beltech 3 inch spindles and bags , now to even it out with the back I have a basic Idea of how I want to do it and how it should look but Id really appreciate some pics of your guy's setups , thanks in advance, Matt
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
same here, I would like to see some two
I got pics but I need to download them from my camera. The pics also show my bag mounts and wishbone!
Needs a Big Block
Id appreciate those fastbagged , I have a couple from the back of your setup some better shots would really help me out!
I would also like to see some pics. I have future plans of doing this, need to learn more about it first....
71 Chevy Long Bed (gettin' bagged) 84 GMC K1500 (Sold) 85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it ![]() 85 Monte Carlo SS clone T-top (Sold) 72 Chevelle-tubbed 64 Buick Sportwagon |
Questionable
I would love to see pics of all the diff't lowered suspension setups people are using and know what they are .... That's one of the posts I see more of than anything else - "show me pictures of your ride height and tell me what size rims and tires you have and how you lowered your ride".
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Formerly ADHDCARGUY
This weekend I'm in the process of converting my ladder bar coil-overs to air bag. '67 SWB. There's about a 2" notch in the chassis.(Bought the truck, didn't build it). Since the bed is off, I'll try to shoot some pics and attempt to down load them here. It's not terribly difficult if you can weld or have a buddy that can weld.
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
Needs a Big Block
I've allready done a 2.5 inch notch , and now its not enough I need a step notch and I know there are alot of strength issues, Id like to see some and get some ponters so it looks right and works right this is mine now
Here is a pic of mine before I installed it. It is 2x4 square tubing.....250 wall. Pretty heavy... I boxed the frame from the front frame horns to the back fuel cell.
Here's some pics that I found on the net a while ago... It was built by "Hot Rods by Glen." I'm pretty sure those are 20's on the back. Just to give an idea...
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Wow is that suspension well done
I omost thought they were 22's on the back.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#13 |
He used to post on here but has been out of sight lately.
#14 |
BK Built
i will post pics of mine soon, ive got a notch very similiar to fastbagged's, one that extends forward to clear the trailing arms. Its a 10" notch and lays frame front to back, with 4" z up front with 3" spindles, and out back i have a watts link in place of the panhard...
#15 |
Hey DroppedChoppedPanel, how do you like that watts link? You bought it from speedwaymotors.com right? I was thinking about using that kit. Lets see some picks
