Old 03-24-2005, 10:36 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Insulationg and carpeting
Sunday and Monday night I got most of the insulation done on the cab. Laid the carpet in the floor yesterday morning and got out last night to get more done.
These are the 98 Silverado 40/20/40 seats I will be using.
Here are a couple pics of the brackets I am using to mount the seats. My intent was to reinforce the floor to some extent due to the fact that these seats have the integrated seat belts. The mounting holes on these seats do not match the existing holes so what I did was add these plates to the top of the floor and then I have also made three plates that go under the floor.
There is a section of C channel welded to the front bracket that the middle seat attaches to.
Underneath the truck I have this plate that is in the raised area below the front bracket.
Then I have two additional plates that both go perpendicular to this plate. One is about 5" wide and connects the front seat bracket to the rear seat bracket nearest to the transmission. Then I have a plate that is about 1 1/2" wide that connects the front seat bracket to the rear seat bracket nearest to the door. My intent is that with these brackets tied together from the bottom of the floor to the top of the floor, I have reinforced the floor where the seats bolt in.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-24-2005, 10:37 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here are the door panels I made a while back. I finished them in the seat material so that ought to blend well together. Martha Stewart ain't got nothing on me.
I laid the carpet in yesterday morning
Then when I got home last night I got out my new handy dandy box knife and cut out the insulation over the kick panel air vents.
A few nights ago I cut a tile backing board to use for carpeting the rear cab wall. I got the carpet glued on that board last night and looks very nice. I considered just gluing the carpet to the back wall but thought a smooth appearance would be better.
I'm not sure how I will secure it. I could get carriage bolts and just use the upper holes that secured the gas tank. However, I think I will try to get some heavy duty velcro or something similar so there is no hardware showing on the carpeted side.
For the kick panels I decided not to go with the premade carpet panels. Instead, I bought extra carpet and cut it to fit. I left extra on the bottom and sides so the floor carpet will sit on the excess and make it very seamless.
For the vent holes I will probably cut the carpet so I can use the excess to flow into the visible portion of the vent hole. Hopefully I can do that and make it look halfway decent.
Overall I am very excited with how the carpet is turning out. I have one area on the passenger side near the hump that is bunched up as a result of the firewall modification. Not sure what I will do about that at this time. Probably won't get out to do more work until next week but I am ready to get the seats bolted down.
Here's a last shot as I'm an
Old 03-24-2005, 10:38 AM   #3
bc gman
71 bb longhorn
Looking good when you put the carpet in was your garage warm ?
71 2500 Gmc longhorn with a 402 turbo 400.
09 F150 Supercrew 4x4
05 Mazda 6 sport
accept that somedays you are the statue
and somedays you are the pigeon.
bc gman is offline   Reply With Quote
Old 03-24-2005, 10:41 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
No. The floor carpet is just sitting in there right now - hope to get a warm evening when I actually go to bolting the seats down so I can get the carpet to fit best. Last night was just a test fit of the floor carpet.
Old 03-24-2005, 10:54 AM   #5
oj70chevy
250 V-6 Club
oj70chevy's Avatar
great info. I am also getting ready to install carpet in my 70c/10 . keep us posted.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 03-24-2005, 11:01 AM   #6
GreyHoundSteve
Man that looks great. Awesome job on the brackets!
GreyHoundSteve is offline   Reply With Quote
Old 03-24-2005, 11:06 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Thanks. There has been alot of talk about the safety of using these type of seats in our 67-72 trucks. I can't say that what I have done is the best or sufficient reinforcement so I would recommend that anyone considering these seats with the integrated seatbelts should do some searching in the past threads and decide for yourself whther to use those seats and how to bolt them down.
Old 03-24-2005, 11:16 AM   #8
GreyHoundSteve
I have 04 trailblazer seats with integrated seat belts i am planning to put in my 67 and i have the same concerns and plan to make similar brackets to reinforce the floor. My seats will be even more difficult though because the bracket on one side sits about 4" lower than the other and i am having to chanel one side into the cab floor. Your brackets give me some ideas on how to mount mine. Thanks for the pics and post.
Old 03-24-2005, 12:57 PM   #9
shifty
Questionable
shifty's Avatar
I really, really dig the gauge cluster. I mean, everything else seriously kicks ass also, but the dash cluster is the one thing that really screamed out to me when it's contrasted against the paint and carpeting.
How much did you spend on the gauges and where'd you get them? Got any closeup pictures of the gauge cluster?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-24-2005, 01:18 PM   #10
Curbstone Mech
Active Member
outstanding! Great idea using the backer board to make a smooth appearance- I'll be staeling that idea for my truck in a few days.Hope you don't mind.
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 03-24-2005, 01:27 PM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's a pic of the gauges installed.
I got all the gauges from Jeg's and aren't that expensive when you look at their individual price but together you easily wrap up about $450 or so in them
Old 03-24-2005, 01:29 PM   #12
shifty
Questionable
shifty's Avatar
Sorry to go off-topic again, but do you happen to have the part #'s for the gauges still? I haven't managed to find a thread at the forum yet which gives anything like that...
Old 03-24-2005, 01:33 PM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
I used the Phantom series as follows:
Speedo 5895
Oil pressure 5829
Tach 5898
Water temp 5837
Voltmeter 5891
Clock 5885
Old 03-24-2005, 01:34 PM   #14
shifty
Questionable
shifty's Avatar
Thanks! Finally, some direction .... Probably going to end up doing them two by two, but anything is better than nothing...
Old 03-24-2005, 01:38 PM   #15
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Great Work Yukon! Keep us posted! Great Pics and Info!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 03-24-2005, 01:56 PM   #16
barn9
Half a bubble off!
barn9's Avatar
Lookin' good Mark! That June deadline is nearing, AGAIN! LOL!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 03-24-2005, 02:18 PM   #17
71-longbed
Its Magically Delicious
71-longbed's Avatar
Is that a molded carpet kit ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 03-24-2005, 02:29 PM   #18
krue
Designated A-hole!
krue's Avatar
Looks good!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-24-2005, 03:01 PM   #19
nathank
resident geek
nathank's Avatar
Lookin gooooood!!
What is the shiny silver stuff you put down before the carpet? Where do you get it and how much is it?
71 C-10 stepper
88 Moostang T-Top w/ lots of goodies
nathank is offline   Reply With Quote
Old 03-24-2005, 03:08 PM   #20
Striker169
Car O'Holic
Striker169's Avatar
wow that is a really clean install nice ++
Striker169 is offline   Reply With Quote
Old 03-24-2005, 03:21 PM   #21
Yukon Jack
Post Whore
Yukon Jack's Avatar
The carpet is molded to fit from Tim Christian. The insulation is from Home Depot and is a foil type insulation. A few other guys here have used it so I thought I would give it a try. I think the name was Reflective Insulation and it is a fairly heavy duty bubble wrap sandwiched between the top and bottom layer of foil. I bought the roll that is 4' wide but I can't remember the length. Seems like it was about $40.00. I will have to see if I have the receipt.
Old 03-24-2005, 04:40 PM   #22
nathank
resident geek
nathank's Avatar
Does the foil insulation act as a good sound dampner (road noise) or what is the reason for it?
71 C-10 stepper
Old 03-24-2005, 04:44 PM   #23
Yukon Jack
Post Whore
Yukon Jack's Avatar
It appears it will quiet down the cab but I don't expect it to do the job that products like Brownbread and Dynomat are designed for. This should be better than stock but by no means am I expecting it to be as good as the more expensive products.
Old 03-24-2005, 04:49 PM   #24
shifty
Questionable
shifty's Avatar
Dynamat and other sound deadeners work on the principle of sticking weight directly to the panel to reduce vibration of the panel. If the shiny stuff in that picture is as light as bubble wrap and it isn't directly adhered to the entire surface of the panel, all it's going to do is block heat, not sound.
I read in another thread where someone got Dynamat or some other type of acoustic matt in a very large amount for around $100.
Old 03-24-2005, 04:53 PM   #25
69 Short Fleet
Your truck is looking really good Yukon, keep it up! One thing I thought I'd mention (maybe you already thought of it) Are you going to put a stereo amp or subs/speakers in the future? Now would be a good time to prewire it before the carpet gets installed. I forgot to do mine and will pull it apart down the road when I get there, Doug
69 Short Fleet is offline   Reply With Quote
