Old 03-24-2005, 10:55 AM   #1
jtminton
II Timothy 4:2
jtminton's Avatar
Gas tank wiring question
I will be putting in a new cab tank in my truck. I need to know where the sender wire plugs into the dash, since there aren't any wires going back there now. PO was going to put in a suburban tank and never did. In the mean time, I'm running off the aux tank, which has no gauge, so is a little inconvienient.
I am assuming it's going to be two wires into some type of plug, but I really have no idea where. My truck is a 72 and the tank/sender is out of a 67. Any other tank installing advice?
Thanks in advance!
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 03-24-2005, 11:04 AM   #2
hot!rod
hot!rod's Avatar
Not sure if the 67 tank is any different than the 72. In a stock 72 there is one wire that goes from the sending unit to the top middle plug on the fuse box. The fuse box is labeled "fuel gauge". Factory wiring takes over from there and sends it to your gauge cluster.
Hope this helps,
Brad
Why do we drive on a parkway and park on a driveway?
hot!rod is offline   Reply With Quote
Old 03-24-2005, 11:07 AM   #3
jhow66
jhow66's Avatar
Just run a wire from tank unit to here:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
