87 Wanna Be K30
two questions...
1. i dont have antifreeze right now so i have been filling my radiator with water. but it seems to almost run out within two days of driving and i cant see a leak anywhere. what could be causeing it?
2. my friend gave me a front 3" lift kit for my 86 k-10 but all he gave me was the two leaf springs. what else am i going to need before i take everything apart and put the springs in? i already have the rear blocks in and now its starting to look funny. so i was just wondering what to order. thanks -Scott |
1. Check your radiator cap to make sure it is not opening at to low of a pressure. Also make sure that your overflow bottle is not cracked and the hose doesn't leak. If that does not seem to be the problem, be sure your enging is not burning it. and carefully check for any leaks.
leak
check your oil,make sure it"s not full of water,also fill it full of water and make sure it's not running right on out the tailpipe.. good luck.
