Old 03-24-2005, 01:30 PM   #1
fastbagged68
fastbagged68's Avatar
Help- Rear Disc Brakes Question
I pulled my rearend out to put my TSM Disc Brakes on my 63 suburban and have a issues.... How are your backing plates attached to your axles....Mine are pressed on or welded on. It is suppose to be bolted to a flange, but I don't have a flange. Does anyone else have the same rearend as myself. This is the orignal rearend. I do not want to replace the housing. It has too much welded to it! Any info on these rearends
fastbagged68 is offline   Reply With Quote
Old 03-24-2005, 03:22 PM   #2
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I'd call the manufacture of your kit. If they said it would fit it should if not they should have some answers. You'd think they'd have instructions.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 03-24-2005, 03:56 PM   #3
fastbagged68
They knew nothing! He was stumped....time to fab something up!
Old 03-24-2005, 07:17 PM   #4
neonlarry
neonlarry's Avatar
Got pictures? Including center section.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-24-2005, 08:12 PM   #5
fastbagged68
Only one I have on this computer!
Old 03-26-2005, 02:29 PM   #6
neonlarry
neonlarry's Avatar
Looks like a 12 bolt, I was thinking maybe you had something else. Both of mine have flanges that the backing plates are bolted to, maybe the earlier ones had pressed on backing plates I really don't know. I guess you could fab something up you are just going to have to get someone with their rearend apart to take some measurements from the backing plate flange to the axle flange. That should be all you need to get the caliper bracket in the correct position to center the caliper opening on the disc.
Old 03-26-2005, 03:25 PM   #7
roj2323
that's a hell of a drop you got going there. how about a closeup of the back side of your drum backing plates? it would really help.
roj2323 is offline   Reply With Quote
Old 03-26-2005, 10:24 PM   #8
fastbagged68
I went down to my shop and looked it over and they are pressed.... They have teeth/grooves that go around the axle and backing plate.... I have another rearend that I'm going to cut the axle flanges from.... Hopefully have it finished next week.
Old 03-29-2005, 04:30 PM   #9
fastbagged68
Well I got the rearend completely apart the other night.... it is an 18spline axle....ya whoa. what do I have! So I bought an Eaton Posi 30 spline, 4.10 gears, moser housing ends and going to buy custom lenght axles now! figured I might as well shorten my rearend another 2 inchs to make it easier to pull the tires off and give me an 1.5 inside the wheel well! All this for rear disc brakes!
