The oddest Todd around
quick 350 question
What are the cons to doing a 0.060 overbore on a 350?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
There is always the concern that .060 may go through the wall. Also, that appears to be the max overbore on the engine so it can't be rebored again.
Jim |
Young truck fanatic
thinner cylinder walls which wont hold up as well to boost...bad with turbo, supercharger...and definatley NO NOS.
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project. **Proud to be Valley Trash** |
Chevys Kick A$$
Yeah, thinner cylinder walls! Won't stand up to a crazy amount of HP and/or the stuff posted in post #3. Plus I do not think it can be rebored again.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
gee,i`ve never had any problem.my 72 is .060 over,my dirt race car is .060 over,i better get new blocks,huh?b/s,never had a problem,and when i do it again,i`ll go the same size.i don`t know what all the hype is about .060 over.how long have they been doing this anyway.i don`t mean to sound rude,but you guys make this sound as if it is something new.go talk to your engine builder,and get the FACTS from them.
72 Cheyenne
Mine is bored out that much and I've heard you can more also but don't quote me on that.
So far I've had zero problems, 400 HP and I drive it like a race car and 180 degrees all day long. |
huh ???
If you think about it, .060 is about the thickness of 6 human hairs stacked toghther...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
its all about the +6 inches
I've seen an .080 over 350 on the street daily driver weekends on the strip in a heavy first gen Monte Carlo in tx.
no over heating problems, and it was fast as h*ll. |
![]() Join Date: Feb 2003
.060
On a .060" over,you're only cutting away .030" of the wall. Not much at all.
#10 | |
Weekend Warrior
.030" means the piston is .030" larger in diameter as .060" would mean the piston is .060" larger in diameter - so how is a .060" only cutting .030" of the wall? as far as the 6 human hairs thing....that's how much the over bore is not how thick the wall is afterwards. as longhornman said...there's guys out there with .080 over 350s with no problems....i wouldn't run one but they're out there. nothing wrong with going .060 on a 350 - just don't excpect to bore it again on the next rebuild.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#11 | |
Look at the picture I am including. ![]() A is the size of the original bore. 4.000 B is the size of the overbore. 4.060 The gray area is the amount of overbore. C is a close up, and as you can see, to make a .060 overbore, you remove 0.030 from the cylinder walls. Todd
