Old 03-25-2005, 12:55 AM   #1
arkracing
Weekend Warrior
WTB Need Pigtail:
I need this but with longer leads...which probably means it will have to be cut back into the harness.
Its the female side of the "horseshoe" plug for the column
anyone got a junk harness (i'll buy the whole thing or just this part)
I need it with @ least 12" of wire...if not more...preferably more.
Like i said i'll buy a whole harness if i have to and cut it up.
or does anyone know how i can get those leads out and get longer ones in? do they make new clips to slid in for each individual wire?
Thanks,
it's for my hot rod but i don't want to splice wires together to get them to the fuse block.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-25-2005, 01:38 AM   #2
kwmech
I just tossed a column in the junk trailer out of my 69 GMC. Still available if I go out there with a pair of dykes.
Old 03-25-2005, 02:20 AM   #3
longhorn71
longhorn71's Avatar
I have one that i could cut out with as much wire as needed.The harnass in bad shape,Just let me know if you want it.
longhorn71 is offline   Reply With Quote
Old 03-25-2005, 05:39 AM   #4
GSFMECH
On the road
GSFMECH's Avatar
Go in from the plug side and there is a small tang you can unlatch with a tiny screwdriver. You can then remove the wire from the plug without cutting it. Don't know if that helps you or not.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 03-25-2005, 06:08 AM   #5
69 Short Fleet
Any pics of the rod?
69 Short Fleet is offline   Reply With Quote
Old 03-25-2005, 07:42 AM   #6
arkracing
Weekend Warrior
Longhorn - Yes interested also interested in the small block throttle rod: PM sent
GFS - i would do that but i would need new metal clips to attach the the new longer wires so that i could put them back in the plug
here is an old picture of the Rod and a pic of the motor....can't find the ones with the bed on it right now..i'm kinda in a rush this morning
-'66 C10 Suburban
Old 03-25-2005, 10:56 AM   #7
mrein3
mrein3's Avatar
NAPA sells the metal wire ends that slip into the plastic connector.
I have the part number in my desk at work but I'm off today. I you still don't have this resolved by Monday send me a PM and I'll get you the NAPA part number.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-25-2005, 08:24 PM   #8
longhorn71
longhorn71's Avatar
got the plug cut out of the harnass with about 17"of wire on it
Old 03-25-2005, 08:29 PM   #9
roj2323
i have the gm part number somewhere. i bought 16 last week for a 68 camaro "same ones" . they were .74 cents a peice.
i'll get back to you.
ondrew
edit:
i allmost forgot. the old wires come out of the plug from the front and the new ones slide in from the back. a little flat head screwdriver will make this alot easier.
roj2323 is offline   Reply With Quote
