What a way to spend the day off....
Well, about 9-10 this morning, I went to the shop and rolled the frame out. Pressure washed it, scraped some more 50 year old grease off and pressure washed again. Then, after a few minutes in the Alabama sun, it had dried completely. I started sandblasting all the frame and finally got finished about 3pm. I was going to go ahead and shoot a few coats of gloss black on it, but the damn store I went to, was out of paint
Street Rod Dreamin'
Location: Work:Batam, Indonesia/ Home:League City, Texas
Must be nice to have a sand blaster!. Epoxy primer first. Some might recommend an teching primer but, going down like you have, I don't think you'll need it. There's alot of different sources but, here's the folks I'll be using when it time for me to buy primer.
www.southernpolyurethanes.com Couple of threads to read: http://67-72chevytrucks.com/vboard/s...ighlight=Barry http://67-72chevytrucks.com/vboard/s...d.php3?t=80127
1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2007 GMC Sierra 4X4 "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it." Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776 |
Well, I've seen a few people just spray it whatever color, right after sanding?
Also, where can I get the epoxy stuff at? I'm trying to save money here and make an every other day driver out of this truck. Does that mean, if I apply the epoxy, I then have to sand it? Then goes the black? This is all very confusing
Street Rod Dreamin'
You shouldn't have to sand it after priming. Click on the link in my previous message for a company that can supply the good primer...OR
order some Zero Rust off of the Internet and call it done (I'd put on two coats though).
Actually, I got it primed today
#7 | |
It just doesn't matter
![]() Join Date: Apr 2001
Not to stick my nose in here, but that statement kind of depends on the type of primer you use well as the time between prime/ topcoat. Any epoxy primer will have a "window" of time that you MUST topcoat it or the primer will harden and will not allow the topcoat to "attach" properly. It will come off in sheets. I am sure any etching primer will work the same way. You MIGHT be able to get away with not sanding a filler type primer, but even that would be iffy after a certain amount of time. Primer is an adhesion promoter when used properly. It is best to make friends with the local body supply place that sells your preferred brand of paint and go there for the straight answers. Just trying to help!!! ![]()
05 Chevy Silverado..... A rogue BMW guy.... If you don't like me- TAKE A NUMBER; There are people ahead of you!! |
Street Rod Dreamin'
Nose stickin' is always welcome on here! There's others (you included) that have WAY more experience than myself. That's the great thing about this board!
Jason, you are doing a great job, keep up the hard work you will be repaid when you go to put it back together!! After it is all back together you and the guy that changes the oil will be the only one that knows how much hard work was performed, because that will be all covered up with sheet metal and wood.A after thought did you explore POR paint, or Paint Over Rust
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
should have just PORed it.. is there anything special about that sandblaster? we have one that is just a big plastic thing with sand in it....then you hook a hose to the gun and a air hose and it syphons it out and shoots....would that work for doing a frame?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
#11 | |
Street Rod Dreamin'
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
A siphon blaster will take a long time to do the frame and heavy parts. Not trying to make a sale here but look at my compressor and blaster for sale under General Discussion/Everything Else For Sale. Read the description. I have used this set up to blast many of my truck parts. It did a great job. To get the job done right you will need a good sized compressor.
I must say it feels good to get everything blasted, primed & painted and start assembly of nice clean parts. Good luck 67ChevyC10stepside on your project. I'm doing a '71 stepside and loving it. Any pics of yours? |
#13 |
i got rid of the GMC clip and got a 67 chev clip....heres the motor as it sits tonight....
