Old 03-25-2005, 08:14 PM   #1
LeftEar55
Do I need to replace or repair these leaves?
Got my frame sandblasted today and it looks like the majority of the rust that was between each leaf, flew out, but what do yall think I should do now? Should I buy all new leaves for each side, (which will be about 800 bucks!), or do you think these will hold up? When the frame is on the ground, you can bounce on the frame as much as you want and there is literally no sagging. It sits level too, even when the body parts were on the frame, it didn't lean to one side, it sat level. Is there a rebuild kit for new clamp thingys? Here's a pic, please let me know what yall think about this?
LeftEar55 is offline   Reply With Quote
Old 03-25-2005, 08:24 PM   #2
72MARIO
72MARIO's Avatar
They look good to me from the pitcure.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-25-2005, 09:04 PM   #3
roj2323
i don't know where your looking to buy your springs from but i got a set for my 85 last year for less than $250. the 67-72 springs are slightly narrower than my 85's and thats why there more. do yourself a favor and update the springs to the later model. you may have to change the shackles but it should all bolt together. good luck
ondrew
roj2323 is offline   Reply With Quote
Old 03-25-2005, 11:24 PM   #4
LeftEar55
Everywhere I look for springs for my truck, they are all about 400 a side. It's because in 55, the 1st series truck had an open rear and it's different than a 55 2nd series and the 47-54's had a closed rear. If anyone knows if anything newer will fit straight into mine, without problems, please let me know.
Old 03-27-2005, 07:56 AM   #5
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
How about taking them to a local spring shop, they will make new "clamp thingys" for you. If I we're you, I'd take them in as they are for a qoute, bring 'em back home to disassemble and clean up, then take them back for re-arch (if needed) and reassembly. I'll bet it would cost less that $100-$150.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
