Old 03-25-2005, 08:24 PM   #1
Wolf
Engine Decoding help
Need some help with this 347 motor.
Can someone tell me what all these numbers mean?
B 34707228
How do I know if it came out of a car or truck?
Thank you.
Wolf is offline   Reply With Quote
Old 04-02-2005, 12:09 PM   #2
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Talking GMC Maintenance manual says..
B 34707228
Thank you.
The 55-59 GMC Truck actually came with the option of two V-8 engines: The 336 V-8 and the 347 V-8.
From the 55-59 GMC Maintenance Manual:
Quote: "The serial number on 8-cylinder engine is stamped on block on right side below manifold to front of drain cock...."
From section 8 page 439: There is a table here of bore sizes............ The manual calls them "Cylinder Bore Selective Sizes" Under a table titled "Code Stamped on top of Block"
Code B = bore size 3.9380 to 3.9385
The standard bore size range was from 3.9375 to 3.9400.
My best guess is that the B in front of the number is the bore size code of 3.9380-3.9385 and (my experience is) that the rest of the numbers refer to the date of the engine build 07(July) 22 [day] and 8 (year 1958).
That is my 2 cents worth. Visit my web site often. rico_bob
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
