Bowtie Overdrives?
I'm thinking of gettin the stage two> If it gets me two more mpg it'll pay for itself in about nine months.
I drag about a 2000 lb. trailer for work with what I have now (350 no lockup) with no problem. Gettin about 9 mpg. 11 mpg without it. What do ya'll think of Bowtie?
82 C-10 Scottsdale LB owned since 89 350 crate vortec heads Crane 1.6 full rollers edelbrock 1406 edelbrock performer eps intake dynomax headers/flowmaster 70's BTO 700r4 level 3 custom 2 piece driveshaft 12 bolt gov loc w/3.08 |
So far they have been very helpfull to me.I have a tci 700r4 with the bowtie tv system for a demon carb, seems like its idleing @ 70 mph, stuff and she will drop in to 2nd and get!!!
Active Member
The only concern I have about what you're suggesting is not BTO, but the 3.08 rear in your profile and OD. With a 700R4 you'd have a 2.15 4th gear (effectively). If in really flat country, it might work, but in hilly Atlanta GA (hi!)
![]() There have been discussions about making sure your main crusing speed is near the torque peak or at least well within the torque output of the engine, or it'll lug and mpg will suffer. This site may help http://www.ring-pinion.com/content/calculators/RPM.asp Brian |
Parts and more parts
My son's truck (86 chevy- 350 motor) had a 700R4 tranny that we put into it, after we took out the 350C tranny. The truck ran down the road at about 1900 RPM and the cruise control worked itself to death, because it had a 3.08 rear end. The fuel mileage sucked really bad 11 to 13 MPG, depending on where it was driven at. The rear was changed out for a 12 bolt 3.73 posi unit and the mileage went UP by 2 MPG. Hard to believe, you ask----well let me tell you the motor runs at 2700 RPM at 70 MPH and the acceleration is smooth with no downshifts to get up and down hills (we live in Kansas where there some moderate inclines that WE call hills). If you put something in the back of the truck it pulls the highway easily and if you tye onto a trailer it handles it real well. I also have a 84 GMC truck with a 400 HP 385 stroker (see the avatar) and a 700R4 tranny and the same gear ratio on the axle, I get 15 MPG when I get onto the highway---Can't complain---The Mustangs do when it jumps them on the ighway.
driving is in my blood
I have a bowtie overdrives stage 2 2004R and a 3.07 rear. Even with 380lbs/ft the engine is working hard at 80mph and 2000rpm. Thats not to say its working too hard, but 3.73's would increase my milage [drove in 3rd one week to test, MPG went up]
As for bowtie overdrives, I would never buy another transmission from them again. The speedo gears went out within 3000miles, one torque convertor lasted 4k, they wouldn't honor my warrenty because I wouldn't modify the shifter to hold it in 1st gear [that was my choice though] and the tech people are hit and miss, somtimes they are nice and somtimes not.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
75 STEPSIDE
I have a 70 buick GS 455. I have a turbo 350 in it now because my son drives it so i took out the 200-4r and 3.42 posi and put the turbo 350 and 2.73 back in. That car was getting better gas milage with the 3.42 and the overdrive than it does now. I am going with a 200-4r in my 75 stepper with a 350 medium cam 3.73 rear end. If you want an overdrive I am rebuilding the 200-4r Got a master rebuild kit, 2800 stall torque converter 13 vane pump kit and shift kit all for 300.00. These 200's and 700's are not hard to rebuild the haynes books take you step by step, so far no problems. I am pretty sure that the 700 is less expensive to build than the 200 i have because of availability. I also want it be known I dont build trannies for a living I am almost done building mine. Give it a shot. Remember one thing that the cable on the 200 and 700 is not just a kick down cable they are throttle valve cables that control ALL shifting they must be set correctly or your tranny will burn up. Also put a tranny cooler on it will add years to the life of any tranny. hope this helps.
Pete 75 Chevy Stepside 70 Buick Skylark/GS |
LED King
I've had nothing but good luck with my BTO Stage II TH700. I love the thing. Best tranny you can buy for the money. Make sure you properly set up the TV cable and the lock-up. They are both crucial. You MUST get an external cooler if you are towing!
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#8 | |
I'd try a couple other tricks for mor MPG before swapping trannys. Run a thermal clutch fan. That netted me 2mpg on one of my trucks. Hook vac advance to a ported vacuum, verify vac advance is good maybe increase static timing, decrease centrifugal timing to maintain current total timing; should help coming out of the hole Try leaning out the Edelbrock in cruise mode, see link: http://www.edelbrock.com/automotive/eps_intro.html reduce acc. pump shot in carb 'til it stumbles on acceleration, then increase 1 step install a heat stove and fully functional OE type air cleaner assy, carbs meter fuel more efficiently with a consistant air temp at the carb Install a 190* t-stat switch to a full synthetic gear oil in the rear axle, full synthetic oil in the motor increase pressure in tires to max rated psi on sidewall lose the bug gard if you have one install an air dam under the front bumper from a later 80's pickup/suburban practice driving like there's an egg on the accelerator pedal
Wise man once told me; "Don't show me what you know, show me what you don't know" Nothing worthwhile is ever easy Present Stable: 73 C-30 CrewCab Dually 4X2 91 4X2 'burban 89 4X4 'burban 84 4x2 'burban (R.I.P.) Last edited by Hemikiller; 03-28-2005 at 05:46 PM. |
#9 | |
#10 | |
![]() The idea behind the ported is you get advance off-idle, and at light cruise, just when the motor really needs it. Full manifold will dimish the advance if you step into the throttle lightly, making you dip into the throttle even more. As far as making a motor idle worse, I'm drawing a blank here. If I set my timing at 10* BTDC, it idles just fine. As soon as I tip into the throttle, the motor gets 10* or more of advance to help in off-idle throttle response. It's when the vac adv is on manifold and it's pulling in ie: 12* plus that 10* initial that it would have a problem, namely keeping a reasonable idle. Then when I dip into the throttle on this setup, the advance goes away and the motor is doggy..... Defense exhibit 1: http://chevyhiperformance.com/howto/97438/
Wise man once told me; "Don't show me what you know, show me what you don't know" Nothing worthwhile is ever easy Present Stable: 73 C-30 CrewCab Dually 4X2 91 4X2 'burban 89 4X4 'burban 84 4x2 'burban (R.I.P.) |
LoL yes the ported vs manifold argument will go on forever, Im just giving the knowlage I've gotten first hand. My vortec 350 will surge at idle with ported vaccum, its rock steady with manifold [thats with 12-14* initial with no vaccum hooked up] Also when crusing high speeds [about 80mph and 2000rpm] if I let off the gas I would get a slight poping out the exhaust, with manifold vaccum theres no problems. I will admit though, when I go to emission I dial the initial back and change it to ported vaccum [works like a charm
