tweed/flamed headliner progress
well i started making my own headliner, used 1/4" closed cell foam to make the flames. i just layed some blue tweed down over it but i messed up in a couple of areas and the spray adhesive saturated through the tweed in a few areas basically ruining it. im gonna try again tomorrow see if i can cover it without letting any glue go through. next up will be the door panels.
Did you buy the door panels that match the Headliners? I was wondering how they fit.
1970 k10 1971 C10 Gilbert Az |
Seņor Member
Looks good.
You may already know how to use spray glue but... Make sure you dust the glue on from a foot away or so. You're not trying to saturate it, just cover it. Spray BOTH pieces and then go grab a Coke. Give the pieces time to dry. After 5-10 minutes, then come back and put them together. Yes, the glue will be dry, and that's actually good. And keep us posted with more pics! Kenneth
Junior Member
What backing material do you use? Cardbord?
67 C-20 LWB 56 Nomad--- nope, sold it ![]() 75 Stingray 13 Silverado crew cab 08 Trailblazer (wife's) ![]() Pittsburgh, PA |
Strongman Garage
![]() Join Date: Apr 2000
that'll look great when finished, good luck second time around!
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
GMC SHORT FLEET F/S
SWEET
CHARLES WADE HEIN HVACR FOREMAN. LEWISBURG U.S.P. |
SKINNY TIRES RULE!
That looks pretty nice. XXL - That is a good tip on the glue, so basically us use it similar to contact cement.
What are you going to use for strength on the door panels. Are you just laying the foam over the original door panels or did you create your own? Also, where did you get the foam?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#8 | |
Bloo
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
![]() Join Date: Aug 2001
Bouncytruck - I've always been able to go to my local automotive upolstery shop and purchase some closed cell foam fairly cheap.
Dropt72shortbed - Make sure you roll those curves good! Should turn out to be nice.
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
#10 | |
Seņor Member
![]() Kenneth
Slowly getting CRSS...
i just did my headliner liek that too, also i did my custom center console the same way, i still have the door panels to do but im waiting on some pieces. soon as i get a digi cam again ill post pictures
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
My dad's 68
I was wondering how hard it would be...........
Did you just cut out the flames and glue them to the headliner?.................. Did you make the headliner? ----Because i've never seen any for our trucks?!?!?................ As far as the door panels go,....Are you gonna use the steel ones?............... .Please E-mail me for im am really interested Biggytyme@aol.com Jack ![]()
Jack M. 67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts ****************************** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 4 12 inch Lightning Audios ****************************** 87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ****************************** Dad's truck 68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more ****************************** grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver* ****************************** 84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames ****************************** S/N=BIGGYTYME@aol.com (hydros) "No fat chics, truck will scrape" |
#13 |
i used a piece of 1/4 plywood for the headliner i just glued the foam to the wood then the tweed to the foam. just have to slowly work it over the flames and make sur it gets pressed between them. actually on the door panels i was gona try yo use the plastic molded ones fro my 72 b/c the have the raised surface for the arm rest. i was gonna inlay the flames on those though.
#14 |
sorry guys
my account was jacked up and wouldnt let me post or reply
as for the headliner, i got the supplies from an upholstery shop. i used a think black board, alot stiffer than cardboard, which is used for making doorpanels and headliners etc.. as for glue im using 3m super adhesive, its for putting vinyl tops on cars but the shop said its better than the regular 3m super 77 and you get ALOT more in the can. the process is pretty simple, cut the board to the shape of your headliner, cover it in one layer of 1/4" closed cell foam the pul another layer of foam over, the second layer draw out your flames and then cut them out. glue the two layers of foam down to the board and then lay your glue over the whole thing and stick your material over, tweed works best. ill post pictures when im done wrapping it in tweed. |
#15 |
flames and tweed
1972 Chevy Custom/10 www.PictureTrail.com/KP1972 Metroplex Muscle Car Club www.PictureTrail.com/DreamCarArt |
#16 |
Boosted Member
Headliner question
How do you guys plan to attach the headliner to the roof?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#17 |
Just curious on how to attach the headliner?
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
#18 |
67-72 Addict!
Colohusker,
You have a few choices: 1. Glue/Adhesive 2. Trim screws with recessed trim washers 3. Velcro- (either heavy duty traditional or 3m dual loc types) ![]()
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
