Old 03-25-2005, 11:44 PM   #1
Broken_down?
truth or stupid idea?
Guy I know told me one day that if you replace the intake gasket on a 350 and crap gets down in the oil pump that you could drain the oil and put 1 gallon of desiel and something like 6 quarts of tranny fluid and run it for a few minutes and that would clean the oil pump filter? I think he is on dope but just thought I would ask.
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 03-25-2005, 11:53 PM   #2
screamin_c102
screamin_c102's Avatar
Thumbs down
Neither of those two chemicals is a lubricant. Sounds to me like your lookin to blow something up in more ways than one.
Thats like 10 quarts of fluid, your gonna have a geyser until evey seal on the motor gives up.
"Stupid idea"
I've heard of adding a small amount of trans fluid to your oil to clean everything up though.
I'd run it with the old oil in it for a few to wash everything down to the pan and then dump the pan.
screamin_c102 is offline   Reply With Quote
Old 03-26-2005, 12:50 AM   #3
67shortie
Green club
67shortie's Avatar
Generally stupid idea, but auto trans fluid is a fantastic detergent oil so adding a quart to an engine has been a favorite in the past with good results.
Just not by itself
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-26-2005, 01:50 AM   #4
3 on the tree
I have added ATF to my oil right before an oil change to clean up sticky lifters. It has always done the trick.
3 on the tree is offline   Reply With Quote
Old 03-26-2005, 02:15 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Anyone who has ever had contaminated oil with fuel or water, will agree that it takes about 4 or 5 oil chainges to get it all out.
I keep thinking about this when i see the super oil chainge deal at the juffy lube places....
Don't do it. It'll clean your engine out OK...but it'll cause thousands of miles of damage in mere seconds.
Old 03-26-2005, 05:13 AM   #6
Broken_down?
thx all. I did not know the tran sfluid acted as a detergent. I will try adding 1 quart and see what happens. If not I have scheduled putting a new 350 crate in this yr. Thanks for info though.
Old 03-26-2005, 08:01 AM   #7
cdowns
cdowns's Avatar
to clean older engines i'll add a pint of marvel-mystery-oil and run for a day or so b-4 changing my oil ,has seemed to work well over the years
Old 03-26-2005, 09:14 AM   #8
RON WOODGEARD
Resident Young Old Dude !
One of my stepdads was a Caddy Certified Mechanic. This was a trick he taught me many years ago.. You do Not want to run it long, but yes it works. Then they did a Double oil change .. And down the road it went..
I have done it and necer had a problem, but you have to do what you feel is best..
RON WOODGEARD is offline   Reply With Quote
Old 03-26-2005, 02:03 PM   #9
pritch
pritch's Avatar
I've never done it as part of maintinence, but I always throw a qt of atf in and drive 10 miles or so before a rebuild. It really seems to help clean things up, sludge and what not. I've heard it's very hard on seals.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 03-26-2005, 04:21 PM   #10
franko72
Franko72
franko72's Avatar
I had a friend who claimed that putting one quart of kerosene in with the oil for about 500 miles helped clean the engine.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 03-26-2005, 09:04 PM   #11
Big Block
Big Block
Big Block's Avatar
If it an't broke don't fix it!
Had a freind who bought a 72 Dodge Dart with slant 6 225ci. with a lot of miles. Don't think the car ever had regular oil changes. He wanted to clean out sluge in engine. I told him I didn't think it was a good ideal, but he bought some engine flush (Reslone) anyway. Well he added a quart and started engine. Engine ran for about 2 min and started to knock. After he pulled the oil pan, he found out why the engine started to knock. The screen on the oil pump was clogged with sluge. This one of those times when it an't broke don't fix it. He only paid $200 for it but it was his only transportation. I think he learned a valuable lesson. B.B
Big Block is offline   Reply With Quote
Old 03-26-2005, 10:41 PM   #12
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Well I guess you could say Reslone works
I read in a mag,Car Craft I think,that a quart of trans fluid every third oil change was a good idea.I've never done it,just don't seem right.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-26-2005, 10:51 PM   #13
kwmech
I do not think in this day and age this should be necessary with the oils that are now available. Engines are running at higher temps where the 'sludge' will not build up. If you have a fairly new engine and change the oil regularly you shouldn't have any problems at all. I pull engines apart that have close to 300k on them with regular changes and they look cherry inside.
Old 03-26-2005, 11:11 PM   #14
Longhorn Man
Actually, ATF is used as a preservitive when storing engines.
Old 03-26-2005, 11:43 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I think I will stick to oil in the engine and tranny fliud in the tranny..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
