Old 03-26-2005, 02:56 AM   #1
bigbruce
Disc Brake Conversion
Wondered if some body could help me
I live in Australia and am doing up a 1969 Chevy C10 Stepside
Would like to know where I could buy a Front Disc Brake Conversion Kit
complete with 2 1/2" Drop Spindles, ball joints, and tie rod ends.
I currently have a friend in USA who will bring kit back with him.
He will be around the Calafornia and Texas areas.
bigbruce is offline   Reply With Quote
Old 03-26-2005, 11:14 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If he is in cali you should have them check out ece early classic enterprises they should be able to help you out..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-26-2005, 11:44 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have the Early Classic Enterprises stuff on my '69. It's been on there since Oct. 01, with no problems.
ECE components utilize stock ball joints, stock brake pads and stock tie rod ends. There are other manufacturers whose kits use different, i.e. special, tie rod ends. The ECE system uses stock GM brake rotors, if you go with the 5-lug. Their 6-lug rotor is what I used, because I already had a decent set of wheels. I can always change over to 5-lug, with GM components. Brake calipers are stock GM. There is something to be considered, in the fact that the parts are stock GM stuff.
They have always been very helpful in any questions that I had.
One thing to remember is that converting from drums to disc, will add about 2 inches width to the front track of your truck. I had to go to 15x7 wheels on the front, to keep them from sticking out past the edge of the fenders (okay, wings). Do you Aussie's use the English terms for automotive parts, like wings, bonnet, boot, etc? Just curious.
I don't think you would make a mistake, to go with the ECE product.
Member Nr. 2770
Old 03-26-2005, 12:04 PM   #4
lpaine
lpaine's Avatar
Welcome from Canada BigBruce;you're gonna love this board
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 03-26-2005, 08:11 PM   #5
greasemonkey
greasemonkey's Avatar
Classic Performance Products is also in Cali, their kits are very complete. www.classicperform.com
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 03-26-2005, 10:47 PM   #6
Low69CST
I like ECE's parts better than any else. Everything I bought fit like parts should fit.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
