2wd to 4wd, are the rubber body mounts the same
I have a set of new rubber body mounts for a 4x4 truck, will these fit a 2wd truck, I am asking because in all of the catologs, they show a different part number for the 4x4's, thanks for your time, Brad
thye are different on the cab for sure-maybe the rad support is the same though?
1972 LWB 4x4 1970 LWB 2wd 1971 chevelle 1972 datsun PL-521/nissan |
Watch out for your cornhole !
![]() Join Date: Jun 2003
If you're talking about a 1/2 ton 2wd, the rear cab mounts are different. The rest of them are the same.
The 3/4 tons, 1 tons, and 4x4's used a real tall rear cab mount. Half ton 2wd's used a much shorter rear cab mount.
'70 GMC C-25 LWB
I have a 1970 3/4 ton and I was woundering what would happen if I used a 1/2ton rear mount instead of a 3/4 ton. I know it will lower it in the rear of the cab but will the bed still line up? I dont think so but i thought I should ask. Thanks
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck |
DTerry,
The 3/4 ton mounts, (same as the 4x4 1/2 ton) are quite a bit thicker. I believe they are about 3 1/2" compared to the 1/2 ton 2 wd which is about 1". The rear of your cab will not line up with the bed and it will be setting on the frame. Jim |
