Old 03-26-2005, 10:56 AM   #1
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
Newbie rebuilding 2 Barrel Carb?
I am think about rebuilding the Rochester 2G Carb off of my 68. I can replace it with a reman unit for $130 or buy a kit for less than $20. Also, if using a rebuild kit, any additional materials or supplies you would suggest? How about buying a kit? Good luck or bad experiences with a particular kit?
Thanks!
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 03-26-2005, 11:55 AM   #2
JimKshortstep4x4
Smile
I have had good luck with the carb kits from NAPA.
Jim
Old 03-26-2005, 12:02 PM   #3
cdowns
cdowns's Avatar
just take your time and follow the instructions, they have carb cleaner in a gallom can so you can dip the carb to clean it it does a great job makes the carb sparkle
Old 03-26-2005, 12:10 PM   #4
68speedalert
Semi-Senior Member
68speedalert's Avatar
It helps ALOT to have compressed air to clean passages. Even with, use an aerosol carb cleaner (again napa is great) to check each passage in it. Check all holes/passages in the body and base. BTW, wear saftey glasses. Nothin like a cold shot of carb spray in the eye to wake you up!
Count the number of turns to seat each mixture screw and write it down. Reset them when putting back together, will help on restarting.
After you get it started and running, shut it off. Look down the throat of the carb and stroke the throttle open. Watch for 2 streams of fuel, one in each barrel, to shoot steady a strongly. I've found a lot of problems with new accel pumps lately. I guess it's because of old stock sitting for a while.
Use NAPA kits only.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 03-26-2005, 01:14 PM   #5
LeRoy
Registered truck nut
LeRoy's Avatar
The only advice I got is give yourselve atleast a couple of hours. Once you start don't stop till finished. It's amazing what you forget. Also the kit is for many different carbs so excess parts in this case is a good thing, lol
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 03-26-2005, 03:04 PM   #6
TruckinDaddy
Great advice, Thanks guys. I'll check out Napa for that kit ASAP. And I am encouraged by LeRoy,
I was thinking it might be a multiple day job.
Cool!
Mike S
My truck blog
My Car Domain page
Old 03-26-2005, 03:11 PM   #7
inline6Bill
A classic GM kinda guy
Relax, take your time, don't rush through it, and you will be fine. If in doubt, double and triple check everything you do.
Old school rap music: a dual exhausted GM 6 with no mufflers.
"If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s.
"I did. They are called Classic GM pickups !!!"
inline6Bill is offline   Reply With Quote
Old 03-26-2005, 07:32 PM   #8
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Use a big table and lay down paper so that you can strategically place the parts as you remove them...even sketch if you need to or take digital pictures. If you have little kids...tape the parts down or they will walk off...LOL...ask me how I know this!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-26-2005, 09:30 PM   #9
TruckinDaddy
I am starting to wonder how guys did all of this BEFORE digital cameras.
I must have taken a dozen pics of the carb before I took it off, trying to get every possible detail and angle. Not to mention all the pics I have taken of rust in the past few days.
Mike S
My truck blog
My Car Domain page
Old 03-26-2005, 10:32 PM   #10
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I must have taken a dozen pics of the carb before I took it off, trying to get every possible detail and angle. Not to mention all the pics I have taken of runt in the past few days.
We had a good remembery
Or stood in the middle of the shop with a hand full of parts,and a look of confusion
It's not a really hard job,just a lot of small parts that all have to be put back in the right place in order for it to work correctly.
Take your time.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-27-2005, 04:07 AM   #11
jimfulco
[QUOTE=TruckinDaddy]I am starting to wonder how guys did all of this BEFORE digital cameras.
QUOTE]
Polaroids!
If your carb is original, don't trade it in on a rebuilt carb. Commercial rebuilt carbs are famous for not working very well. If you need more than a home-grown rebuild, take yours to a shop & have it done. It's already calibrated for your engine & it will work much better than a "fits-all" rebuilt unit.
jimfulco is offline   Reply With Quote
Old 03-27-2005, 02:20 PM   #12
TruckinDaddy
OK, one more question before I decide to try it myself. The carb was leaking fuel. It was most noticeable dripping slowly from the throttle linkage. Should a rebuild take care of this? I assume so, if it is just a failed gasket.
