Old 03-27-2005, 11:47 AM   #1
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Can I put radials on 16" split wheels from a 52
The 3/4 ton 52 that I am still looking at has the original 16" two-piece (split) wheels...can I put modern radials on these wheels?
Do modern day 8 lug wheels fit this truck?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 03-27-2005, 06:36 PM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I tried some steel wheels from a stock 3/4 ton,and they hit the tierods in the front and won't turn.I did put some aftermarkets on it just to roll it around and they work fine.DIfferent offset I guess.Bolt pattern is the same though.
I would think you could run a radial on a split rim with a tube in it.I just hate splitrims,really dangerous,and I hate to mess with them.
Here's what I put on it to roll it around,and they work fine.Maybe this will help.16x8,not sure about the backspacing,I can find out tomorrow if ya want.At least there will be an idea of what will work
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-27-2005, 09:03 PM   #3
8t5Silverado
I'd appreciate it...I'm not too wild about the split wheels myself.
Old 04-01-2005, 02:46 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Just so you know, the 52 3/4 ton came with either 15 or 17" wheels. They are a two-piece lock-ring design. Nothing wrong with them as long as the mating surfaces aren't pitted from rust. You can run radials on them, but you have to run a tube. To have anyone work on the wheels you need to locate either a truck tire dealer or a Co-op. No one else wants to work on them.
Problem with running newer wheels is the backspacing, like Brainchild said. You can buy spoke style wheels that work, if that's your style. Wheels from the 80's or early 90's gm trucks need about a 2" spacer to work on the front, which aren't cheap. Need to be the style that have their own studs mounted and bolt onto the drum. Another solution is to find a wheel shop that will cut and weld the centers of newer rims to fit.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-01-2005, 10:11 AM   #5
8t5Silverado
Thanks for the info...that stinks. I wanted to find something cheap for the time being before I update the running gear with 5 lugs (which I can't afford to do right now). I guess I will just have to make these work for now.
I was told they were 16's (the owner of the truck has a good set of 16 inch tires he was going to give me with the truck), but I haven't gotten to inspect the truck yet.
Do you guys know what the backspacing should be? I assume 3" or less.
Old 04-01-2005, 10:37 AM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
On my 15s it's about 3-1/4". Original tire size was 7.00-15 6 ply.
Fred
Old 04-01-2005, 03:35 PM   #7
8t5Silverado
Thanks.
