Old 03-27-2005, 11:50 AM   #1
chevybill
chevybill's Avatar
Exclamation Home Alignment - anybody do this?
Do any of you align your trucks' front end at home?
I have seen several tools to do this and their price range varies greatly.
J C Whitney even shows alignment tools.
Please post thoughts, tool sources etc.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 03-27-2005, 12:33 PM   #2
jamis
F.A.S.T. president
jamis's Avatar
The only thing a would do at home is toe in. I wouldnt spend any money on tools to do alignments at home. cheap tool gets you a cheap alignment. On of my co-workers those his own alignmet on on of those IMSA cars for varing track conditions and coarses. But for a street driven car its best to get a good alignment with a reputable shop. Some places do a crap job.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 03-27-2005, 12:37 PM   #3
cdowns
cdowns's Avatar
a good mechanic with a good alignment machine is well worth the cheap price of a proffesional alignment. i've seen alot of do-it yerselfers break thier ass and knuckels trying to, only to find out 500miles later that the only thing they accomplished was trashing a set of tires
Old 03-27-2005, 05:02 PM   #4
chevybill
chevybill's Avatar
thanks guys,
anone ever attempt this?
Old 03-27-2005, 05:14 PM   #5
72MARIO
72MARIO's Avatar
I am going to set the rough toe in so I can drive my truck to the alignment shop. For the price it cost you can't go wrong having a good shop do it for you.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-27-2005, 11:57 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
While I tend to recomend a shop like everyone else here seems to be doing, I'll say that I have enver taken one of my rides in to be done. All i ever used was a T square and a tape measure. We do many trucks like so at work too.
Old 03-27-2005, 11:58 PM   #7
Longhorn Man
Oh....never had any tire wear issues either....well...the right rear always seems to have problems keeping tread, but I think that may be unrelated.
Old 03-28-2005, 12:03 AM   #8
CHEVY & GMC FOREVER
Hey Longhorn Man how's that motor going ???
1985 Chevrolet C-30 454 1-TON Dooley
1969 CHEVROLET CST-10 PICK-UP
Good memories
1999 Chevrolet Z71 Ext. cab 5.7L
Good Memories
With a quart of oil, and a gallon of gas, she won't let no other car pass!!!.
& FOREVER
CHEVY & GMC FOREVER is offline   Reply With Quote
Old 03-28-2005, 12:05 AM   #9
screamin_c102
screamin_c102's Avatar
I smacked a curb and bent the a-arm on my s-10 one night does that count?
I out-a-aligned it
Take it to a shop they can only charge ya for a two wheel alignment and they're cheap.
screamin_c102 is offline   Reply With Quote
Old 03-28-2005, 12:33 AM   #10
Longhorn Man
The one that lost oil pressure and started knockin like a diesel?
It's doin fine sitting in a storage unit collecting dust.
Old 03-28-2005, 01:27 AM   #11
69ChevyLB
Active Member
69ChevyLB's Avatar
Hey Andy. Would you care to explain how to do it with a T square and tape measure? Wearing the inside on the right front. Thought this might be a camber problem.
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 03-28-2005, 02:07 AM   #12
jhwkns
Registered Cruiser
jhwkns's Avatar
I do my own. I've got a caster/camber gauge, and a bar that I use for checking toe. I learned how to do front ends when I was a kid working at an import garage, and nowadays I work on a lot of stock cars. A nice flat spot to set your car on, a decent caster/camber gauge, and a toe bar will tell you all you need to know.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 03-28-2005, 10:16 AM   #13
wxman1
I've know guys who have set toe using a set strings. But they also
used a tread depth guage once a month to check how the tires were
wearing.
Jim
Mt Juliet
wxman1 is offline   Reply With Quote
Old 03-28-2005, 06:51 PM   #14
Longhorn Man
I measure to the center of the tire, and mark it with bright paint...same on the other tire. If it is a tire with tread in the center...I just move it over and make sure the other one is marked the exact same.
Roll the vehicle so the painted mark is in front...as close to the 1/2 way mark (measured from top to bottom) on the tire's rotation. If you can't get too high, then it won't be as acurate...so you want to get it as high as possable. However, don't let the tape touch anything.
With an assistant holding the end of the tape measure directly on the painted mark on one wheel, you slide to the other side and pull the tape tight. You don't need to rip it outa the other dude's hand, but you need to be consistant on how tight you pull it.
Record your numbers.
Roll the vehicle backwards untill the painted mark is 180 degrees from where you started...again, as close as you can, the higher the better, and again, the tape must be unobstructed.
Record the measurements.
You want about 1/16 to 1/8th inch toe in....toe in is when the front of the tires are closer than the rear of the tire... like this as seen from above. \----/ But not nearly as wade obviously. And just for sh1ts and grins, this is toed in as seen from above /----\
Loosen the rie rod sleve that connects the inner and outer tie rod together, and adjust acordingly. If an uncentered steering wheel really bugs you, then there is more work involved...and it is a good idea since driving with the steering gear box uncentered will shorten it's life, only the center of the gear is heat treated, and keeping it on a turn spot of the gear would end up wearing it out. You'll need to adjust each side in or out while keeping the steering wheel centered. Kinda tough to do, and can really try your patients.
Test drive it, paying close attention to where the wheel is, if it is just a little off, and you're OK with it, then it's OK. Pull back in and re measure it all....same steps, and perferably using the exact same paint dab...to keep things consistant.
Also, when pulling in to adjust it/recheck it, you are better off coasting to a stop, or stopping with the E-brake.
For the Camber...the tilt of the wheel, I have always gone for perfectly verticle, maybe 1/16th inch with the tops tilted out. Like this as seen from in front of the vehicle. \------/ ...again, not as drastic. Generally, if the vehicle's weight has not been altered, (ie...a big block where an inline used to reside) then the adjustment needed will bo to tolt the tops out, as springs get old and sag, the top of the tire ends up tilting in. Like this /----\ Or like the rear tires of an old escort or tempo.
You need a very smooth flat surface to do this on, have the truck loaded like you would every day. The spare in it's space, your tool box loaded if you keep it so, and even toss 200 pounds into the drivers seat to represent you and your spare tire.
I may have used the worong term...carpenter's square...the long L shaped tool, normally (if not always) imprinted with your inch/mentric measurements. You want it to be perfectly straight. The taller the better. I used to have one that would reach the rim , but not go to the tire on my old longhorn which had 9.50 16.5 up front.
I would place the tool on the floor, and slide it up against the tire. No forcing, you need to measure the gap between the tool and the rim bead. (after ensuring the rim is straight....and many are not). Do it on both top and bottom.
To adjust it, you add/remove shims inbetween the upper a-arm mounting bolts and the frame. add to tolt the top of the tire out....remove to tilt the top of the tire in.
Again, go around the block, roll to a stop and recheck it.
This is not going to get you dead on acurate like taking it to a shop with the real expensive computerized lazer allighnment rack. However, either i have been dam lucky, or this is enough to get you in the window.
On solid axle trucks, (like the GM P/30) we set the toe all the time at work, and have sent one or two out to get checked on a machine, and both times the dude said they were close enough to warrant not messing with it.
Also, be forwarned, you may bust bolts...you're dealin with old/rusty stuff here. Be prepaired to locate SUTIBLE replacements, not the five and dime replacement grade 2 stuff either.
Also, this can take up the better part of an afternoon your first time, we can set the toe on the P/30's we rebuild in less than 30 min including test drive and remeasuring and centering the wheel. But this is after rebuilding 100 or so trucks too.
In all reality, I recomend setting the toe this way after replacing components, and then drive it to get done properly.
if you are dead broke and can hardly keep the gas tank filled, then this will get you close enough to keep from needing tires in 2 or 3 months.
Old 03-28-2005, 09:18 PM   #15
chevybill
chevybill's Avatar
Talking thanks longhorn man!!
This was the type of reply I was looking for, I know I can take it to a shop and will when finished. I have rebuilt my front end (as part of a ground up project) and want to get it close, until I get to the alignment shop and to show my alignment guy just because the truck has been lowered (in a proper fashion with spindles) that it in fact can be properly aligned.
Any other replies regarding home alignment tools?
Old 03-28-2005, 11:34 PM   #16
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
i use a digital protractor to set camber initialy. set toe similar to above post.
set the castor to prevent dive.
then i use a nice straght road & a ir temp sensor to check tire temp spread.
when the settings are right the temps will be within .5 degrees acroos the tire.
measure inside, center & outside.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 03-28-2005, 11:50 PM   #17
68C15
blood type; Retumbo
68C15's Avatar
home brew alignemts can be done. I have highly modified my front end. I set the toe, camber, caster & ackerman all at work using nothing more than a tape measure,& a home made fixture for adapting a magnetic protracter.. then when I bought new tires I figured I would take it in for a pro job. (this guy is a perfectionist) he said he had to add 1/16 shim on all 4 bolts to get it perfect!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 03-29-2005, 07:01 PM   #18
hotrodtroy
hotrodtroy's Avatar
If he tells you it can't be done slap him stupid(er). lol
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
Old 03-30-2005, 12:33 AM   #19
robertwb
I've done toe with the parrallel string method and it works good-haven't got into caster/camber yet but it's just a matter of time and tools...like evrything else
robert
1972 LWB 4x4
1970 LWB 2wd
1971 chevelle
1972 datsun PL-521/nissan
robertwb is offline   Reply With Quote
