Old 03-27-2005, 08:09 PM   #1
soulman67
Randy churchill
soulman67's Avatar
Parting out 72 C20
I have a 72 that I am going to part out. Most of the front sheetmetal is dented beyond repair. The turck has a 4 speed and a 8 lug 10 bolt rear with 4.10 gear ratio. Just post what your looking for and I will post a pics and a price for it.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires
2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10
2003 Jeep Rubicon 4.5" short arm lift
1985 Jeep CJ7 30k in parts and still adding up
soulman67 is offline   Reply With Quote
Old 03-27-2005, 09:40 PM   #2
Striker169
Car O'Holic
Striker169's Avatar
Cab Doors Seat Bed Brake Booster?
Striker169 is offline   Reply With Quote
Old 03-27-2005, 10:31 PM   #3
soulman67
Randy churchill
soulman67's Avatar
I will sale the whole truck for $500 or $350 without the vin & Title. The truck is beat up from being a ranch truck since it was new. Until 4 months ago when the engine was pulled.
Old 03-28-2005, 11:30 AM   #4
chuck call
chuck call's Avatar
Is the rear end an eaton or dana. I am looking for an eaton 10 bolt 8 lug 4.10
chuck call is offline   Reply With Quote
Old 03-28-2005, 01:00 PM   #5
jtminton
II Timothy 4:2
jtminton's Avatar
PM Sent
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 03-28-2005, 01:11 PM   #6
soulman67
Randy churchill
soulman67's Avatar
On the rear I am not sure, whats the difference? This is the first 10 bolt 3/4 ton axel I have delt with.
Old 03-28-2005, 02:05 PM   #7
chuck call
chuck call's Avatar
I am pretty new with this to ,but they say you can remove the whole center section, it unbolts on the driveshaft side of the rearend
Old 03-28-2005, 02:21 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Is the grille good?. If so how much shipped to 21236?. Same for the headlight bezels. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-28-2005, 04:14 PM   #9
soulman67
Randy churchill
soulman67's Avatar
On the rearend just the cover unbolts.
Old 03-28-2005, 06:34 PM   #10
soulman67
Randy churchill
soulman67's Avatar
The grill is good for a driver, its been repaired in one spot and has scuffs. The inner grill looks good with a few cracks. The complete grill with headlight buckets $175. plus shipping, I'll have to get a box and weight. If you want it I will pull it off and get a shipping qoute.
Old 03-28-2005, 11:56 PM   #11
70c10
67-72 Addict!
70c10's Avatar
Randy, I'm going to pass. Thanks
Jim
Old 03-29-2005, 12:20 AM   #12
72 Cheyenne K20
Any of the wiring harnesses. Need engine harness (V8). Cab harness (no A/C). Tail Light harness.
Scott
72 Cheyenne K20 is offline   Reply With Quote
Old 03-29-2005, 12:23 AM   #13
gregbr
Senoir Member
gregbr's Avatar
How about the power brake setup (without master cylinder).
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 03-29-2005, 12:43 AM   #14
soulman67
Randy churchill
soulman67's Avatar
Scott I will sale the whole wiring harness for $100 dollars shipping is included for that price.
Greg on the power brake setup, do you just want the boster?
Old 03-29-2005, 07:18 PM   #15
gregbr
Senoir Member
gregbr's Avatar
I need the booster, any brackets, nuts/bolts, hose to engine, & rod to pedal. Would also be interested in the brake lines from the master cylinder if they disconnect on the frame below. Also need rear bumper brackets with nuts/bolts, and the throttle cable & pedal. Let me know.
Old 03-29-2005, 07:26 PM   #16
Striker169
Car O'Holic
Striker169's Avatar
Hows the cab? is it useable any dents major dammage? and how are the rockers and kick pannels? any pics of that?
Old 03-29-2005, 11:41 PM   #17
soulman67
Randy churchill
soulman67's Avatar
Greg I don't have rear bumper brackets, Everything else I might can I'll let you know on a price after I get them off.
striker169, the cab has some damage right above the windsheild on the drivers side. The doors are in good shape the rockers are rusted and so is one cab corner. All the floor suports are there and look to be in good shape. I will post pics tomarow. I'll take $300 for the cab & doors with all the glass or $350 for it with vin & title.
