Old 03-27-2005, 10:07 PM   #1
shortymac83
hmm...
shortymac83's Avatar
bed side question...
well...here's the problem...my bedsides are kinda rotted. In the JY, there's a steel bed with a dented to hell floor, but the bedsides are good (dented wheelwells, but I've got those). Are they interchangeable? and by interchangeable, I mean bolt on? If so, I may grab 'em...
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 03-27-2005, 10:17 PM   #2
screamin_c102
screamin_c102's Avatar
yep, its all pretty much bolted together back there. You might have probs with the rust though, take some PB Blaster with you and some long breaker (cheater) bars.
screamin_c102 is offline   Reply With Quote
Old 03-27-2005, 10:50 PM   #3
moodybo
moodybo's Avatar
yeah there is usually a little tack weld on the rear of bed down close to where the tailgate hinges. You will need a cutting wheel,grinder , or torch it off both sides. If you dont you will bend some metal you probably dont want to!
moodybo is offline   Reply With Quote
Old 03-27-2005, 11:12 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very simple swap there are 2 tack welds in th rear tailgate area on each side that need to be delt with just unbolt the reat you may want to bring along a fattie phillips screw driver as there are 2 big phillips screws up top in each front corner to deal with..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-27-2005, 11:35 PM   #5
screamin_c102
I think those screws are like #4 phillips arent they? They are friggin huge.
Old 03-28-2005, 09:03 AM   #6
If you have one,bring an impact wrench(the kind you hit with a hammer).
Old 03-28-2005, 01:18 PM   #7
shortymac83
hmm...
yeah, I know about teh tack welds on the back shelf, the wood bed has those too (though one withered away and is loose now), I was just curious if they did bolt on.
