Old 03-28-2005, 01:07 AM   #1
HatGuy
HatGuy's Avatar
Lightbulb Need some opinions (motor & trans)
Well it’s planning time for 2006. My 72’ K5 Blazer Highlander now has 147,000
Original miles. So it’s time for some decisions. First of the year I will have $5,000 to spend and I need some input.
1 Motor. After pulling the original and seting it aside for safe keeping
should I install? These are on Summit Racing's web site at : http://www.summitracing.com/
a. GM Complete 350 cid 330 HP Crate Engine NAL-12496968 $3,495.95
b. GM 350 cid 290 HP Crate Engine NAL-12499529 $1,818.9
c. GM 350 cid 260 HP Crate Engine NAL-10067353 $1,419.95
d. Rebuild the original 350 motor . Price ?
2 Trans. After pulling the original and seting it aside for safe keeping
should I install?
a. 700R4 Level 1 Part #:L1MP700R4 $895.00 http://www.bowtieoverdrives.com/cata...m.php?ITEMID=7
b. Rebuild original Turbo 350. Price ?
Rear end is 3.73:1 but not Positrack. Thinking about 32” tires.
One other option is just keep driving it Utill something breaks then fix it.
It smokes (on cold start up), leaks every thing (a little bit). It's my daily
driver but its only 5.5 miles each way to work.
Thanks in advance
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 03-28-2005, 01:34 AM   #2
jhow66
jhow66's Avatar
Here's my .02 worth of info:
1- a-best buy for the money-good street engine (good TQ which you need if you go to bigger tires). Have ordered and installed 2 of these for friends-no problems to date.
2-350-cheaper-you will have to have special adapter to mate with your tranfer case with 700. Would take a long time to make up the differance between the cost of 700 and the extra gas mileage it might get.
(PS-this advice might not be worth 2 cents)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-28-2005, 06:30 PM   #3
HatGuy
HatGuy's Avatar
Thanks, jhow66
What other items did you need to buy with the 350 Delux 330hp?
72' K5 Highlander
My Daily Driver
Old 03-28-2005, 07:47 PM   #4
jhow66
jhow66's Avatar
You should not have to buy anything as you already have a 350 in truck--just use what parts you need off it.
Old 03-28-2005, 09:13 PM   #5
cnshoot
cnshoot's Avatar
i would check the gm dealer in your area if you know a parts guy it helps but you will save in shipping than using a place like summit but if you want the best deal for the money use a good machine shop in the area and for the money you could build a 375-400 hp for the same money i know there are some pepole from this board in the dfw area that could lead you to a good place
72 cst 2wd blazer sb soon to have tilt manual
72 gmc swb fleet 2wd bb air tilt auto
93 c/3500 crew-cab dually
03 chevy suburban LT quadrasteer c/2500 4x4
cnshoot is offline   Reply With Quote
Old 03-28-2005, 09:15 PM   #6
cnshoot
cnshoot's Avatar
also check the salvage yards for a votec 350 you will have to change some things but can be a great buy for the money
Old 03-28-2005, 10:55 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I bought a new gm crate motor for my blazer about a year ago and have had no problems with it.. Gotta be the best thing I have done to the blazer to date...Just my 2 cents worth..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-28-2005, 11:23 PM   #8
DANL
Hey Hat, I vote keep driving it until something breaks and then rebuild the original units.
...Dan
DANL is offline   Reply With Quote
Old 03-29-2005, 09:02 PM   #9
Paul72
Paul72's Avatar
The plan for my Blazer is to build a 383 out of the original motor, put on vortec heads, bolt on a 700R4 w/a 208 X-fer case, and new driveshafts F/R.
The 205 X-fer is stronger than the 208, but I don't plan on doing any serious wheeling with it once it's done (and I'm too cheap to buy the adapter for the 205).
5 grand will go a long way (if not all the way) to completing the project.
My .02
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 04-03-2005, 03:37 AM   #10
HatGuy
HatGuy's Avatar
FRENCHBLUE72,
Which crate motor did you buy?
Will you post or email me a pic
of your Blazer so I can see the
32" tires.
72' K5 Highlander
My Daily Driver
