Old 03-28-2005, 01:47 AM   #1
shifty
Questionable
shifty's Avatar
Parts cleaner?
This doesn't really fit under engines nor under body work. Not sure what forum to post in, so I'll just stick it here.
What do you guys use to clean the grime off of your engine parts? I want to clean stuff like this tranny crossmember, steering box and other crap, got any suggestions? It's like ... grease + sand caked all over everything:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-28-2005, 03:14 AM   #2
ACES
Life is a gamble
ACES's Avatar
For a running truck, I just take it down to the local self car wash and spray it heavily with degreaser, let it sit for a few minutes, then spray the heck out of it with the sprayer. Of course being careful not to knock any electrical connections.
The underneath is kinda a pain and I always end up wet. So if anyone has any better suggestions, I'm all ears.
-ACES
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 03-28-2005, 06:34 AM   #3
Zeke
Active Member
Various size putty knives, put some plastic down to help with clean up then to the car wash to get all wet.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 03-28-2005, 07:41 AM   #4
67mbsc
In a pinch, oven cleaner works just like engine cleaner
67mbsc is offline   Reply With Quote
Old 03-28-2005, 09:12 AM   #5
tripp
cleaner
oven cleaner works great. it will take the paint off sometimes if the parts are hot. make sure you have good ventilation when you spray that stuff.
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 03-28-2005, 09:44 AM   #6
72gord
Never enough time!!
72gord's Avatar
I used a putty knife for the thick stuff, then soaked it with an engine degreaser and let it set for a couple hours, then blasted it off with a pressure washer.....yup, you get soaked too!!
72gord is offline   Reply With Quote
Old 03-28-2005, 10:59 AM   #7
boogie67
boogie67's Avatar
cleanup
I use a cleaner called the purple stuff putty knifes and a pressure washer also. my sons truck had it on like cement.Had to use screw drivers and hammers on some pieces.Came out clean.
boogie67 is offline   Reply With Quote
Old 03-28-2005, 11:04 AM   #8
saxmo
saxmo's Avatar
I pulled my I6 drivetrain out...scraped the main grime off with a putty knife...sand-blasted the rest down to pretty metal... blew out the sand with air compressor..painted with chassis saver...put v8 drivetrain in...but this may be a bit on the extreme side...
2004 Corvette Coupe Black LS1 (daily driver)
1973 Ford Bronco (resto/mod @ 95%)
1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said)
1997 Ford F150 4.2L 500k+ miles (trash hauler)
2011 Nissan Juke (wife's daily driver)
1943 Ford GPW WWII jeep (waiting its' turn)
saxmo is offline   Reply With Quote
Old 03-28-2005, 03:20 PM   #9
shifty
Questionable
shifty's Avatar
Sounds good to me
I'm just curious - they sell a lot of cleaners at the store. I have several boxes of sample-sized grease lightning, but I doubt that stuff is good enough for what I want to do. I also have a few cans of Berryman B-23 laying around, I used those with a wire brush to clean my engine mounts and other stuff when I swapped engines. Just curious to see what other people found useful.
It's a messy job, that's for sure.
Old 03-28-2005, 04:26 PM   #10
meathead95
computer illiterate
meathead95's Avatar
i like castrol super clean it works great
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 03-28-2005, 04:39 PM   #11
busterwivell
I like the oven cleaner route. and you can get the stuff at the 99 cent store. last engine i cleaned up took 5 cans, but it's clean, regasketed, painted up and ready to drop in.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-28-2005, 05:15 PM   #12
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Regardless of my initial steps, which often include "original" oven cleaner - not the new user-friendly stuff - I use Spray-n-Wash and a good brush for the final cleaning. I find that it removes any residues and washes off well enough to accept paint with no problems.
Also works great on tires.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 11-30-2010, 10:54 PM   #13
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Parts cleaner?
I always do a search before posting, and I try to post in the most relevant and newest thread. Most threads talk about steam cleaning or using engine cleaner that requires rinsing with water afterward. My engine has been pulled recently, and I'm taking care of a few of the leaky gasket issues, and I want to clean the grime on the block before putting the parts back on. From searching these forums, I'm leaning toward using kerosene.
Anyone see a problem with this?
66 C20 Service Truck:
Old 11-30-2010, 11:03 PM   #14
meathead95
computer illiterate
meathead95's Avatar
Re: Parts cleaner?
I use kerosene in my parts washer. I have noticed when the kerosene get old and dirty it leaves a residue on the parts so I usually go over them with brake cleaner or mineral spirits before paint.
72 2wd blazer
72 swb 4x4
Old 11-30-2010, 11:06 PM   #15
fattyarbuckle
Re: Parts cleaner?
leave it on because it'll rust. J/K
I bought a 78 and washed it at the car wash till I had no more beer money, then i washed it at home for three days laying on my back in the driveway with my pressure washer... I ended up taking everything out re-building and fixing leaks then painted...
I couldn't stand everytime I worked on the truck having to take my cloths off in the garage before I come into the house. LOL
fattyarbuckle is offline   Reply With Quote
Old 11-30-2010, 11:10 PM   #16
LostMy65
LostMy65's Avatar
Re: Parts cleaner?
I'm thinking I'll use kerosene, and after I get the engine back together and running, I'll use one of the products where you first warm up the engine, and then rinse with water.
Old 11-30-2010, 11:13 PM   #17
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Parts cleaner?
1 Oven cleaner (use it ventilated, stout stuff!)
2 purple power
3 steam cleaner (pressure washer works ok, but that hot water takes the grease OFF)
4 engine degreaser
My favorites are 1 and 3 lol
John
1999 Toyota Tacoma 4x4
