Teflon tape..yes or no?
Does anyone use teflon tape on their brake, and tranny connections?
2004 Corvette Coupe Black LS1 (daily driver) 1973 Ford Bronco (resto/mod @ 95%) 1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said) 1997 Ford F150 4.2L 500k+ miles (trash hauler) 2011 Nissan Juke (wife's daily driver) 1943 Ford GPW WWII jeep (waiting its' turn) |
![]() Join Date: Mar 2003
NO! that's what the double flare is for.
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
exactly
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
works good in kitchen and bathroom , cars not
Glowing since 1978
Teflon tape is a good thing on pipe threaded fittings. Stuff like water pump pipe nipples and intake pipe nipples are fine. The compression fitting is what is suppose to seal the hard line connections. Not the threads. If a compression fitting won't seal it needs to be replaced. They are not good for life so to speak. Each time they are taken apart they need tightened a little more to get a seal. Eventually, they won't seal correctly no matter how tight you make them.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
anything that has pipe threads. Like the fitting that screws into the water pump for the heater hoze hook-up. Or the oil pressure line hook up at the back of the block.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
kewl... was just wonderin'
If it makes you feel better you can use teflon paste on the threads. Similar to tape in that it seals threads. Since it is a paste not a tape, no strings can travel.
Franko72
teflon paste or tape will make turning those threads easier when you make them up.I put teflon on all tapered threads and sometimes on flare fittings just to make the thread glide easier.Teflon is not a sealant, only a lubricant to help a tapered thread reach its make up home.
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
Teflon tape is a wonderful thing, and as franko72 says it makes turning threads easier... in fact so easy that when I was installing the pipe thread brass cooler line fittings into a aluminum transmission case they went in so F___ing easy that I cracked the case (you can only imagine the expletives streaming from my garage that day) so be judicial when torquing fittings when using this stuff.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Franko is correct, or at least that is what i have been taught as well, that Teflon tape is for lubricity and NOT sealing purposes.
"lubricity" ......they didn't use words like that where I come from....LOL
Telfon tape? always! |
