Old 03-28-2005, 11:28 AM   #1
nevada70chev
Inside Sterring column ???'s
what is in the inside of an automatic steering column besides the steering shaft, wiring harness and shifting hardware? i want to mount a tach to the column, but i dont want to use a hose clamp. i was thinking of drilling and tapping thread into the column body and mounting it that way. has anyone tried this before? will i have enough clearance to drill and tap with out damaging the internals of the column? any other feedback is welcome. thanks. i just want a cleaner install without the hose clamp, am i
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 03-28-2005, 01:49 PM   #2
jhow66
jhow66's Avatar
Just take out one of the screws that hold the netural safety switch and check it for lenght. Nothing you can hurt by drilling there. (use sheet metal screws like the switch--no tapping this way)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-28-2005, 03:19 PM   #3
nevada70chev
ok, i will take a look at it, hopefully it will be as easy as i anticipate. should also be a cleaner looking installation. thanks if it works i will have pics.
