03-28-2005, 01:25 PM | #1 |
I'm watching you!
Drum brake springs
Hello again to everyone.
I'm doing a brake job on my 68 and replacing shoes, hoses, spring and adjuster kits, and the wheel cylinders. When I went to the front I noticed the left front drum had a crack in it. I went to AZ and purchased 2 new drums for the front. The old drums have a spring that wraps around the outside of it. I have 2 questions about that. 1. What is that spring for? 2. Do I have to put it on the new drums? I have included pictures below of the old drum, new drum, and the crack. Any help will be appreciated. Thanks in advance, Mike |
03-28-2005, 01:35 PM | #2 |
Resident Curmudgeon
I did a search for you.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-28-2005, 03:21 PM | #3 |
i just did the drums, wheel cylinders, shoes, hardware on mine. i think the outer springs on the drums are for noise reduction (sqeeky brakes).
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
03-28-2005, 03:48 PM | #4 |
I'm watching you!
CPNE thanks for the search. I didn't realize that function was back up until now.
nevada70cev did you put the springs back on with the new drums? If they are just for niose reduction I don't think I'm gonna put them on, but I'll keep them around in case the niose comes out and bothers me. Thanks for the help. Mike |
03-28-2005, 03:58 PM | #5 |
my sentiments exactly, my rear drums had the springs. i am keeping them just in case.
03-28-2005, 04:30 PM | #6 |
Seems like when I did mine that the spring would not stay in place on the new drum. It wanted to roll off because the lip on the new drum was not made for the spring. So I run mine without and have no noises.
Be careful taking that spring off. When I did it, it rolled off so fast it caught my shirt and pulled out a bunch of belly hair!
Gaddman Scottsburg, In 67 SWB w/93 step bed 68 LWB Fleetside C10 Custom 50 Chevy 3600 74 Norton Commando 850 72 Norton Commando 750 Last edited by gaddman; 03-28-2005 at 04:34 PM. |
