Old 06-06-2002, 05:49 PM   #1
bluzman2004
Homemade bed covers
Anyone made their own bed covers? I am thinking about doing one of my own and could use some ideas.
Thanks,
69 Chevy ProStreet, Low and wild.
78 Corvette
rturnpaugh@compcams.com
bluzman2004 is offline   Reply With Quote
Old 06-06-2002, 06:03 PM   #2
PushinPebbles
My dad's 68
PushinPebbles's Avatar
My dad made one out of ply-wood and covered it w/ vinyl..............It acttually looks pretty good......................If im not mistakened he made the supports out of alum................His trucks bed is SWB stepside.......sorry no pics
Jack
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 06-06-2002, 06:05 PM   #3
Smooth68
Smooth68's Avatar
I did my last one - went to a local camper shop and got some 1" light weight aluminum square tubing and made a frame. Then attached 1/2" angle to the sides and made some sliding hinges for the front - I covered the top with a piece of fiberglass sheet like big freezers use, put some foam down then covered with black vynil.
Not to offend anyone but I wouldn't do the wood route - it may last for awhile but it will eventually warp and buckle - heavy too.
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 06-06-2002, 06:30 PM   #4
BOSS
Just here to help
BOSS's Avatar
does anyone know where you can get a big ebough piece of plexiglass to cover a short fleet?been thinking about mounting speakers there and thought it might look good......thanx
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 06-06-2002, 07:07 PM   #5
Benrs86
Benrs86's Avatar
i work with a lot of plexiglass stuff where i work, making gaurds for machines, im not sure where we get it from, but we get 4 by 8 sheets. it would look awesome im sure, but be super hard to keep clean!. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-06-2002, 08:50 PM   #6
XXL
Seņor Member
XXL's Avatar
I used to buy in 4x8 sheets from Cadillac Plastics in Dallas. I think they are now part of GE (at least, www.cadillacplastic.com redirects to GE's site). You might want to get your tape measure out though... the bed is more than 48" wide, so you'll have to do some splicing.
Kenneth
XXL is offline   Reply With Quote
Old 06-06-2002, 10:31 PM   #7
Benrs86
Benrs86's Avatar
a nice 1 or 2 inch wide peice of polished aluminum could go down the center of your bed, that would look nice holding the pieces together, as long as you polish it up good, and do something about the bolts. good luck, and post pics if you do it!, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
