Old 03-28-2005, 04:33 PM   #1
Low87
been here longer than Liz
Low87's Avatar
how do I change the door lock cylinder?
I need to change the door locks on my truck. Anyone know the best way to do this? Planning on taking the panels off and figuring it out, but if anyone has done it I'd appreciate a heads up.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-28-2005, 05:19 PM   #2
Jonboy
Slots go on anything!
After removing the door panel, you should be able to see the retaining clip for the lock cylinder. Once that is removed, you should be able to wiggle the lock cylinder out of it's hole. Installation is reverse of removal
1974 Jimmy- 5.3/4L80e/NP241
Old 03-28-2005, 05:48 PM   #3
low 84
low 84's Avatar
take the door panel off, and look at how its attached, its a no-brainer from there
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-28-2005, 06:42 PM   #4
Low87
Low87's Avatar
You're assuming quite a bit of me...
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 03-28-2005, 08:50 PM   #5
Low87
Low87's Avatar
It was very easy! Took about 30 minutes for both doors.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
