Old 03-28-2005, 08:18 PM   #1
402Bowtie
402Bowtie's Avatar
4x4 question
Today I installed my 4x4 axles and put on my rotors and spindles on the front end. When I spin the "dealy thing" (don't know what it is called ), only the left axle spins. If I spin the right axle by hand, the "dealy thing" doesn't rotate. Why does the left but not the right axle engage when the "dealy thing" is spun? Thanks for the help if you have any idea what I am talking about.
402Bowtie is offline   Reply With Quote
Old 03-28-2005, 10:05 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It's an open differential. They do that.
Or, your talking about the axle shafts w/ the small u-joint, if so then the hub is not engaged on the right.
What year truck and axles?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-29-2005, 12:12 AM   #3
402Bowtie
402Bowtie's Avatar
yeah that's it....... I have a '72 chevy k20....so it's supposed to do that on the front end?
Old 03-29-2005, 01:17 AM   #4
brad juan
sounds like your hub on the right side is now locking in.
1972 chevy C/10, with factory air, SWB, 350,700r4, lowered 3 and 5.
brad juan is offline   Reply With Quote
Old 03-29-2005, 03:02 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, sounds like your hub on the right side is not working.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-29-2005, 05:01 PM   #6
Esteban86K5
Esteban86K5's Avatar
It's not necesarily a hub. He did mention axle and not tire. A good way of testing it is by locking in both hubs. Have someone hold your left tire while you turn your driveshaft. Your right tire should turn. Then do the oppostie by holding your right while you turn your driveshaft and your left should turn. If you see you axke shaft turning but not the tire then yes it would be a hub. If nothing is turning I would pop that diff and check it out.
Be American Buy American
My Pics
Esteban86K5 is offline   Reply With Quote
Old 03-29-2005, 08:23 PM   #7
402Bowtie
402Bowtie's Avatar
I don't have my hubs installed yet (I am actually looking for a good used pair or even maybe a single), but I have everything else installed up to that point. Once again, I spin my driveshaft and only the left axle spins. If I spin my right axle by hand only the driveshaft turns. Is it supposed to do this, sounds to me like I only have 3 wheel drive? Thanks.....John
Old 03-29-2005, 11:19 PM   #8
Esteban86K5
At first you were saying that when you spun your right axle the driveshaft wouldn't move. Now your saying it does. If it does then the only problem you have is a stock open differential. That's how they work. When one tire is on the ground and one is in the air. Only the one in the air will spin. SO unless you have a locker in the rear, you truely only have 2wd and any given time.
My Pics
Old 03-30-2005, 01:27 PM   #9
402Bowtie
402Bowtie's Avatar
alright thanks for the help....you guys are great.....john
