Old 03-28-2005, 08:51 PM   #1
benscool1
benscool1's Avatar
Rear suspension bolts?
I'm switching the rear suspension on my truck to a different chassis, leafs, differential, hangers and all. Well I have all the rivets off but the hole is a weird size, its bigger than 3/8 and smaller 7/16. I think I might have to use a metric. I'd prefer not to have to drill EVERY ONE of the holes out to 7/16. What did you guys do? Can you get metric grade 8 bolts anywhere? I'd need a cobalt bit to drill them out, and that would cost me an arm and a leg. What have you guys done? Like I said, if I can get a metric to fit that would be awesome, but I don't wanna have to drill out all the damn holes unless I have to.
BTW, to save myself the trouble of starting another thread, will a bezel out of an 84(but the guy says it has the wiper controls in the dash, not on the turn signal) fit a 73?
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 03-29-2005, 04:18 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
Metric bolts are not measured by "grade", instead they have a number indicating the quality standard. 8.8 class is equivalent to grade 5. 10.9 is equivalent to grade 8. The number should be stamped on each bolt&nut. 10mm is slightly bigger than 3/8 but smaller than 7/16.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 03-29-2005, 08:59 PM   #3
1FaastC10
1FaastC10's Avatar
the rivets are 3/8". my entire chassis is held together by 3/8" bolts, no problems whatsoever getting things to line up.
1FaastC10 is offline   Reply With Quote
Old 03-31-2005, 01:26 PM   #4
us111
holes
i also used 3/8 grade 8 bolts to replace the rivet's..when i done mine i took a grinder to the rivet head's then beat them out with hammer and punch..some were easy other's were pretty tough.
us111 is offline   Reply With Quote
Old 03-31-2005, 02:58 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Drill the hole out to use grade 8 7/16 bolts. It is stupid to go undersized and take a chance on the bolts moving around and causing a distrtion in your metal. I did it with the bed on my truck once and it can be done.
piecesparts is offline   Reply With Quote
Old 03-31-2005, 05:52 PM   #6
us111
bolts
sorry,boy i said that wrong,(been a while since i done mine)..i DID drill the holes out and went to the larger bolt so it was a good fit...wasn't that hard to do,just used a good drill bit...sorry for the miss information...
Old 03-31-2005, 07:17 PM   #7
1FaastC10
1FaastC10's Avatar
it is also stupid to do more work than necessary, especially when the cause for doing more work isnt really that big of an issue. the outer diameter of the bolts are .37", and the diameter of the hole is .385". use a good quality lock nut, and you'll never notice the .015" difference. any tigher, and you would have issues with getting all of the bolts into the parts easily. threading them through the holes isnt good for them, as it wears the threads right off the bat, causing their clamping force to be less.
Old 03-31-2005, 07:47 PM   #8
piecesparts
OK; Whatever you want to use on yours, I chose the other method of going to a 7/16 bolt. I felt that drilling out the rivet hole to that size was not a real hard issue and with that approach I had the comfort of putting a bigger and well-fitting set of bolts into my truck's substructure. To me the extra work was worth it. I am somewhat of a BIGGER is better kinda guy.. By the way ever hear of a Charpy V-notch test ? It has to do with shear factors of metal and distortion when put under certain conditions. That is why I went to the extra effort.
Old 03-31-2005, 11:12 PM   #9
benscool1
benscool1's Avatar
Yeah, thanks for all the info guys. I picked up a few good bits and used some drilling oil and already have all the holes drilled to 7/16 on the hangers but I still need to do it on the frame rails. I was surprised how much easier it was w/cutting oil and a good bit.
Ben
84 C10 Silverado
14 Silverado Z71
