fuse block ?
What do you guy's clean the fuse terminals with?
Mine are rusted. Just trying to find a way to clean them up. Thanks, Matthew
69 swb stepside, rebuild and upgrade in progress |
Grab your wife's emery board when she isn't lookin, the plastic ones are best as they don't conduct.
If you can't get an emery board then use a points file after you disconnect the battery. |
Questionable
They should be copper terminals, right?
Steel wool.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
![]() Join Date: Feb 2003
the last time I had to clean one I used a Dremmel tool with the small wire wheel. It was quick and very easy.
Scott |
Thanks Guys,
Off to the tool supply. Matthew
69 swb stepside, rebuild and upgrade in progress Last edited by matt67350; 03-29-2005 at 10:14 AM. |
