How much does your ammeter needle move?
With ign. off (or on), and headlights on, my needle BARELY moves to the left. I would have expected more. Is this all you get? Fuses by radiator are OK.
Thanks. 72 C10 |
Ok
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
newly minted old timer
thats all i get, verry little motion. the gauge is just a bit better than the idiot light. not by much though
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
That's all mine did, but I switched to a volt meter underdash till I restore the inside of the cab.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
Dang! Sounds like something I DON'T need to work on!
Resident Curmudgeon
![]() Join Date: Dec 1999
It only registers the degree of charging or discharging from the battery. If the charging system is up-to-snuff and working correctly, it should move but just barely from center depending upon the load on the system.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Glowing since 1978
If you want it to move a bunch, then disconnect the distributor positive lead and crank the piss out of the engine and then reinstall the positive lead. Start the truck and you will see the needle deflect alot more. That is when the charging system is sending a lot of juice to the battery. It is true that a healthy charging system will cause very little ammeter movement. A bad system on the other hand will be noticeable. The needle will move away from that center position. Telling you that the battery is supplying the load or that the alternator/generator is having to charge the battery way to much.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
user # 2756
![]() Join Date: Jun 2001
Turn on the lights/wipers/blower fan and it'll move more, w/engine off.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
