Old 03-29-2005, 11:32 AM   #1
griswold510
leaf springs on a 2wd c10
is it possible to replace the front coil springs on a c10 with a set of leaf springs off of a blazer? if so what all would be needed to do this?
griswold510 is offline   Reply With Quote
Old 03-29-2005, 11:40 AM   #2
Greenlee
Greenlee's Avatar
To put leaf springs in the front of a 2wd you would have to cut out the A-arms and put in a straight axle. Why would you want to do that?
Greenlee is offline   Reply With Quote
Old 03-29-2005, 11:49 AM   #3
griswold510
no one makes a lift for a 2wd.
Old 03-29-2005, 01:08 PM   #4
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Look here...
http://67-72chevytrucks.com/vboard/s....php3?t=146610
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 03-29-2005, 06:55 PM   #5
griswold510
yeh i already have 1 ton coils and a 3" body lift. just want MORE. so i was figuring this would be the cheapest/easiest way to do it.
Old 03-29-2005, 08:00 PM   #6
SanitysBane
If you are going to all that bother, why not just get a 4X4?
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 03-29-2005, 08:31 PM   #7
1FaastC10
1FaastC10's Avatar
its way more work than its really worth
i would highly advise against a swap from your current setup to a 4x4 setup to anybody. if you want a 4x4, sell your truck and buy a 4x4.
1FaastC10 is offline   Reply With Quote
Old 03-29-2005, 08:38 PM   #8
SanitysBane
That what I ment Jeremy, if you are going throw the bother of setting up leafs on the front, then buy a 4X4.
'88 K5 Blazer
Old 03-29-2005, 09:47 PM   #9
griswold510
the truck is a family truck so i wanted to at least keep the cab for sentimental reasons.
Old 03-29-2005, 10:21 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes it can be done. You will need everything from the 4wd truck to make the conversion. Your going to need the spring hangers, shackle mounts, steering box, etc.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-30-2005, 01:25 AM   #11
griswold510
i was thinking of just throwing a front axle from a 4wd under it. what all will i need n2?
