Engine size in a 63 C10?
I just bought a 63 C10 that has a straight 6 in it. How can I tell if I have a 230 or a 292 in it? I was searching for an enhaust system for it and RockAuto.com has one for each.
Thanks |
230 side covers are about 4" tall, 292 is about 6" tall, 292 has a bypass hose near the upper rad hose. Also the fuel pump & mount are swapped, from front= dist-fuel-pump-mount on 230, dist-mount- pump on 292.Brian
Thanks. It turned out to be a 230. Although it probably fits both, I need a complete exhaust system and found on at rockauto.com. I just hope I can get the bolts loose at the manifold!
#4 | |
Re: Engine size in a 63 C10?
It's Better With Nitro
Spray the fasteners down a couple of times with penetrating oil (Kroil, Gibbs, etc. your preference) over a few days before trying to bust the hardware loose.
Moderator
![]() Join Date: Dec 2012
Use an air impact. Use heat if needed.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#8 | |
I bought the Walker pipe from Autozone and it had crinkles where the tubing was bent. I stopped by a local muffler shop and he could actually custom bend new pipe for a little cheaper than the Walker parts cost me. Plus, I have a short bed and the Walker pipe only came in long bed size. I would have had to cut out part of the rear section and then weld the pieces together if I had kept the Walker pipes. The donut is available from vendors or the parts stores. The insert for the donut is also available from vendors. My exhaust manifold bolt holes were bad so I had heli-coils installed and they have held up great. I was able to install all the exhaust pieces myself and I had a muffler shop to go to if one of the bends needed adjustment. Just sharing my experience and not the only way to go.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
230 motor mounts are straight across from each other and 292 are staggered. Also side covers, as has already been addressed.
#10 | |
Post Whore
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
