Old 06-06-2002, 10:54 PM   #1
MJN
MJN's Avatar
diesel power options?
A friend of mine wants more power from his 6.2L diesel in his '85 K/10. It has a lot of torque already and he has dual glasspack exhaust. He is saving for a turbo but until what can he do to get some more ponies?
Old 06-07-2002, 05:12 AM   #2
feg05
First open up the exhaust. The glasspacks are restricting the flow. Go to a high flow muffler like flowmaster. Also use a larger exhaust like a 2 1/2 or 3". With exhaust restricted you'll get more torque, but since diesels have such high compression, you need a larger exhaust. You could also turn up the injector pump, if it has a mechanical pump. These mods are cheap. You could go to larger injectors and possibly some head work for more hp. but these mods would be more money. The money would be better spent on a turbo, like you mentioned.
75' 1/2 ton shortbed 468 bbc 541hp. on dyno,th400 with Coan 3500 stall,12bolt with 3.73 posi.
feg05 is offline   Reply With Quote
